InfiniteJester
- Joined
- Feb 2, 2024
- Messages
- 458
- Likes
- 490
To me the Delci were a bit glary and way too bright, I think is the shallow fit/short nozzles I even asked Kefine for a new set filters which they graciously send me at no cost (just shipping) but same result, I tried EQ and mesh filters with bad results then as a last resort I punched a hole in the filter and surprisingly it worked then I added a 200 mesh filter on top and that tamed the brightness and glare for me (with out affecting too much the rest of the FR... I think), I love the sturdy, small and light weight design plus they are the most comfortable IEM I have ever tried. I had the same problem with the Zero:2 which are also a shallow design but with those I gave up trying to EQ or filter them after a while and stopped using them.
The EW300 look very good on paper but I'm afraid it can have the same issues for me, is the fitting close to the Delci or are the nozzles longer?
I couldn't get a good fit with the Zero:2s no matter how many different tips I tried. But I get a good fit with the Delci and the Simgots. Looking at them side by side, the Simgots seem a tiny, insignificantly portion larger, but the angle is different enough and, in fact, I find the angle of the Delci more comfortable.
I do use gigantic tips with them (I don't know the name of the tips, there are just black XL generic tips).
The Simgots are less bright than the Delci above ear gain/4KHz up to 10-12KHz, the Simgots do seem to have an accentuated "air" due to the way the piezo has been implemented, and it can be a little "artificial" or "exaggerated" some times, but I didn't find the Delci too bright with most tracks. Consider that I use an IR with them most of the time that made them warmer. None of these IEMs hurt me the way that Zero:2s, Quintets or FH9 hurt me with their unrelented brightness.
The surprising thing is that the new Simgots measure really close to the Zero:2s, but the later sound incredibly wrong for me. Like truly terrible: distant, bright, congested, claustrophobic... Probably because it is impossible for me to get a good seal with them.
