- Thread Starter
- #21
I can give you one piece of strong advice about portable speakers. The watt numbers are worse than useless, ignore them. Whether they are accurate, made up entirely, or just inflated (usually the latter two) they don't tell you anything about how loud the speaker goes. (they never mention sensitivity, do they??) My company was fairly honest in terms of wattage, but our competitors were lying about watts so much that my CEO eventually decided to publish peak numbers only.
If you can, find some independent tests that measure SPL and/or frequency response, that's the only thing that will really help you decide other than listening for yourself.
Even in the hi-fi world, watts don't tell you too much about loudness. A large horn speaker like the Klipschorn can do >100dB SPL with around 1 watt. A small inefficient bookshelf speaker may only do about 83dB with 1 watt... a difference of around 10x SPL.
Watts are used as a proxy for loudness because consumers are trained to look for that number, and they feel that they understand there is a direct relationship between watts and loudness. Unfortunately that is only true for a single speaker, you can't compare volume across speakers via watts.
Hello, about HOM, wich one do you advice that could fit my needs ? Thank you.
