In fact, a lot of people expect distortion (even IMD) to present itself as a very unpleasing sonic signature, While this may be the case if it is mostly on the bass, one must understand that distortion is always on harmonics, and therefore it will ADD strength to the signal at higher frequencies. This will obviously ("mathematically") imply two things:
1) increased volume at higher frequencies - and therefore a Purifi module will sound as if treble had been rolled off; and,
2) accordingly, higher separation at the treble, because the added artifacts will be more independent of each other, possibly resulting in a wider image, even though less stable
A signature aspect of high-tier Class D amplifiers is that the image is stunningly stable, not particularly wide, but with a deep stage, and sounding a bit rolled off in the treble with respect to high bandwidth AB amps.
Some key aspects for me are: stability of the staging, and, for orchestral classical music, very extended yet smooth treble, with a dark tone for strings. These are telltales of a realistic take and rendition of the recording, the latter confirming the quality of Purifi and Hypex modules.
You can get a wider-than-recorded scene, but it won't be sculpted, it will become larger at larger sound pressures and shrink when softer. Just use Class A. Well one Class AB can vary from very close to Class A to very close to Class D.
Roberto
