It is an incredible explosion of them. With of course next to no data to pick from them and hence my testing.They just keep coming. It is never-ending. Test budget target growing like earlier Bit Coin?
I have been searching for this for months but it was not available in US until I saw your link above! It was designed by JohnW (active on pinkfishmedia forum). So thanks for posting it. I see it on Amazon too which is nice. Given that I am way over budget for this month, I will consider purchasing it come the new year.This probably goes outsude the bargain category at least in terms of low price but given its support for DSD512 maybe $399 isn’t too bad?
http://www.pro-jectusa.com/en-us/pr.../dac-s-and-sources/s2-line/pre-box-s2-digital
I do have a project to quantify mains leakage through switchmode power supplies.I was thinking that measuring the non-DC stuff coming out of separate PSs may be worthwhile but many wall-warts are anonymous products and even if one was found to be outstanding it may not be possible to confidently find one to purchase.
That may be a better project: Bargain power supplies.
BTW, there was an issue with early units where the contract manufacturer substituted parts without permission from John. I wonder if that is fixed now.
Hi all
John Westlake confirmed here that the correct components were used in all units of the Pro-ject Pre Box S2 digital. A review of this unit would really be interesting. The specs tick all the right boxes, incl DSD512.
Thanks for sharing. On the same forum, John also said this about the USB input - "Yes - true, no galvanic isolation like the MDAC and 95% of DAC's I guess...". Can someone shed some light on how important galvanic isolation of USB input is? My main PC for instance spits out crap through its top USB ports which translates to audible noise on my USB headset; is this a problem galvanic isolation would solve? If so, why is this absent in 95% of the DACs as John claims?
No evidence but I believe it would remove the ground loop hum issue I experience with my PC > Emotiva DC-1. I use Toslink to work around.Thanks for sharing. On the same forum, John also said this about the USB input - "Yes - true, no galvanic isolation like the MDAC and 95% of DAC's I guess...". Can someone shed some light on how important galvanic isolation of USB input is? My main PC for instance spits out crap through its top USB ports which translates to audible noise on my USB headset; is this a problem galvanic isolation would solve? If so, why is this absent in 95% of the DACs as John claims?
It might lead to issue demonstrated in this video:Thanks for sharing. On the same forum, John also said this about the USB input - "Yes - true, no galvanic isolation like the MDAC and 95% of DAC's I guess...". Can someone shed some light on how important galvanic isolation of USB input is? My main PC for instance spits out crap through its top USB ports which translates to audible noise on my USB headset; is this a problem galvanic isolation would solve? If so, why is this absent in 95% of the DACs as John claims?
BTW the initial wording that iPurifier fixes that was not correct according to his later posts.
This is noise that is being picked up by the USB ground and travelling to the output of the DAC whose ground is connected to the shield of USB. Once there, it will keep going downstream.
