Has anyone considered a similar Multi-Channel Music-based chain utilizing a Roon streamer HDMI out (could be a very simple/cheap NUC-based streamer) to the VanityPro to the miniDSP DDRC-88D then to the Okto DAC8 Pro for a 7.1 music-based multi-channel setup? I realize the fidelity limitations of this chain would be based on the miniDSP DDRC-88D's performance, which hasn't been tested/measured. Amir has reviewed the miniDSP DDRC-88A, which got a very marginal pass/recommendation. But the miniDSP DDRC-88D is a different animal that does it all in the digital domain. This chain's performance would depend on the jitter or any noise the miniDSP unit might add. You would get Dirac Live room correction in a separate (non-PC based) box, to an otherwise very high-fidelity chain (only limited by the performance of the DDRC-88D). I'm a multi-channel music fan that has always been looking for an affordable solution to room correction that doesn't involve a PC.
I know many posters here seem to be concerned with the VanityPro's potential integration with their audio-video Dolby Surround or Dolby Atmos based setups. But, I'm not sure that's what it is being offered for (I guess not, since it doesn't support any of those codecs). It seems to me that that Audiopraise could be testing this out with a potential "audiophile" multi-channel music-based audience? HDMI has in the past been considered a very poor medium to transmit high-quality/high-resolution audio, but are they attempting to make it somewhat of an alternative to the traditional USB-based audio setups? Maybe multi-channel music, besides otherwise being almost dead, may have a future with Dolby Atmos? I don't know - but, if so, then I get these objections to this unit not supporting the Dolby Atmos codec . . . just sayin' . . .
The chain I was proposing above, although admittedly multi-component, is still a whole lot cheaper than the very excellent, but also very expensive exaSound S88 MkII; now $7,600.00 -- course, that's what I really want, and it takes a Roon Ethernet streaming input! (but, sadly no real room correction).
- John
