I'm feeling kind of entropic today.Good ol' thermodynamics.
I'd say that it killed poor Boltzmannn, but when it's all said and done, it kills everybody.![]()
Pick up your mess.I'm feeling kind of entropic today.Any suggestions?
Well -- Don't do what Boltzmann did!I'm feeling kind of entropic today.Any suggestions?
... and contribute to the heat death of the Universe?Pick up your mess.
Maybe the distortion rise is not only by frequency but by input level too.Yes.
The Distort software does not do distortion rising with frequency according to its designer, although he said he had written the code for it but never released it because he thought the idea was a too arcane for most people. But most amps using feedback have distortion rising above a certain frequency (dependent on the GBP and how much loop gain is in the design). So without that feature Distort is a bit of a red herring if your goal is to model how audible distortion is in most amps.
As you know the ear treats the 2nd and 3rd as being pretty innocuous, so yes, you have to add a lot to really hear it. IIRC GE did a study back in the 1960s that concluded that people will tolerate up to 30% THD if its all 2nd but I read that in a book and never found it online. Of course there was something similar to this effect published in the early pages of the Radiotron Designer's Handbook, 3rd edition (published in the 1930s). I was clued into that bit by John Curl.
Right now I'm of the opinion that distortion vs frequency might be more important than actual THD in terms of how audible the distortion might be. Its worth noting that many class D amps of the self-oscillating variety such as Hypex tend to have no rise in distortion with frequency because they have excellent GBP values, like a lot of the better opamps around these days. So they have that plus very low THD to start with- a one two punch.
Regarding evidence, did you try the demo test I mentioned a little bit ago- the one with the amp, speaker, generator and VU meter? If no, its really worth doing because otherwise its hard to understand how the ear can be so sensitive to higher ordered harmonics. After you do that demo, its pretty obvious. That's the first bit of evidence.
I must have missed this- could you link or give me a short description?Regarding evidence, did you try the demo test I mentioned a little bit ago- the one with the amp, speaker, generator and VU meter? If no, its really worth doing because otherwise its hard to understand how the ear can be so sensitive to higher ordered harmonics. After you do that demo, its pretty obvious. That's the first bit of evidence.
How so? Looks pretty normal to me.Really strange stuff.
Total newbie,I'm used to DAC and solid state stuff (note,extremely limited collection,newbie operator and ancient interface),so...How so? Looks pretty normal to me.
If you look at the left side of the first graph, that's noise dominated, that is, the THD+N measurement shows a constant (more or less) noise floor with the increasing signal level causing a decrease in the THD+N measurement until you hit the point (in the middle) where the distortion starts rising above the noise floor (the right side) and dominates the measurement.Total newbie,I'm used to DAC and solid state stuff (note,extremely limited collection,newbie operator and ancient interface),so...
It's good to know it's normal,thanks.
There's no THD+N in this measurement,it's broken down to noise and THD only,that's what I thought is strange.If you look at the left side of the first graph, that's noise dominated, that is, the THD+N measurement shows a constant (more or less) noise floor with the increasing signal level causing a decrease in the THD+N measurement until you hit the point (in the middle) where the distortion starts rising above the noise floor (the right side) and dominates the measurement.
The distortion spectrum is also pretty normal for a preamp that has active devices in push-pull (i.e., third harmonic is dominant, 2nd is a function of side to side imbalance, perfect balance cancels all the even order components).
I'm not a user of REW so I can't diagnose what you did or how the software interprets the data, but that curve is absolutely THD+N.There's no THD+N in this measurement,it's broken down to noise and THD only,that's what I thought is strange.
That will depend on the FFT parameters.Noise is constantly at about -104db
It's not REW,it's @pkane 's Multitone Analyzer.I'm not a user of REW so I can't diagnose what you did or how the software interprets the data, but that curve is absolutely THD+N.
I'm certainly familiar with GedLee, but their work is for distortion levels and distributions that one doesn't generally see in amplifiers.
Well, no-one would argue that 50% harmonic distortion isn't audible.
I have the original Musical Fidelity one in cylindrical case. It added warmth to cruder sounding CD players such as the CD63 KI Signature player. I did the Rock Grotto updates to mine including special valves he recommended and it became so transparent there was absolutely no need to use it any more as it made little to no audible difference! he's taken it further now but no idea how 'different' it is audibly. The thing now lives in the loft with other stuff I've accumulated.That's what's fueled the market for $50 (USD) "tube buffers" for a generation!![]()
If they actually were buffers, they'd do nothing (except, possibly, you know... buffer). Instead, I think most of them have been little "effects boxes" (i.e., distortion generators).
dang! this one's 120 smackers!?!
IWISTAO Tube Buffer Preamplifier X10-D Music Fidelity 6N11 No Gain
IWISTAO Tube Buffer Preamplifier X10-D Music Fidelity 6N11 No Gain AC12V Power Adapter Sweet Natural Taste HIFI Audio X10-D Music Fidelityiwistao.com
or just whip up something like this.
source: https://www.worldradiohistory.com/B...ooks/RCA-Receiving-Tube-Manual-1954-RC-17.pdf
... or...
source: https://www.worldradiohistory.com/B...ooks/RCA-Receiving-Tube-Manual-1961-RC-21.pdf
I'm not sure what you are asking. Is this having to do with Distort?Well, no-one would argue that 50% harmonic distortion isn't audible.
Now do the same thing with the same relative harmonic distribution but, say, at 0.5%. What happens?
That is unless you're are clipping along at 35wpm.I thought we were arguing about digital, not binary. If you assign a number to something, it only works if everyone else does as well, so we can understand and translate it as a number as well as giving those numbers other meanings.
As it happens, Morse code has either four or five values, according to definition:
a long "on", dash
a short "on", dot
a long "off" between letters
a longer "off" between words
and arguably, a very short "off" at the end of a dash or dot (the very short off can be said to be part of the dash or the dot)
It's another example, going back to an earlier comment of mine, of something that is arguably digital or not, but is not in fact binary when it comes to definition and meaning. Even though the key is either down or up...
There should be some information theory that applies to this, separating the binary "on off" from the values, but I can't remember the terminology used.
He could run the speaker wires through a waa-waa pedal, as he taps his foot to the musicThat's what's fueled the market for $50 (USD) "tube buffers" for a generation!![]()
... or...
a long on ... = dahI thought we were arguing about digital, not binary. If you assign a number to something, it only works if everyone else does as well, so we can understand and translate it as a number as well as giving those numbers other meanings.
a long "on", dash
a short "on", dot
ah yes.....good times - good times AR EEThat is unless you're are clipping along at 35wpm.
Benchmark is not classDI go by my experience on other forums. At one in particular which is a very long-standing forum, (shall I name it?), a very high proportion of members are against class D -- even though many have actually recently owned or tried class D in their systems.
The typical remark is that the "tone" of class D isn't right; it doesn't sound "natural" like live performance, especially the treble. In fact the "tone" deficit they refer to is easily explained by the lack of 2nd/3rd order distortion they are getting from their tube equipment or S/S such as Pass Labs. Some of them will admit this explanation, some will not.
But there are a few audiophiles whose tastes have evolved. I can think of one who was a stalwart of tubes for decades but is now loving his Benchmark preamp and power amp. Kudos to our member, @atmasphere, who was and is a maker of highly regard tube equipment, who is now also making a class D amp of his own design and is, happily, selling lots of them.
