By whom, and using which test format?I think I want to test whether short or long listening times give better identification performance...
Anyway, to get back to the topic of the thread, there are a few examples of subjectivists who turned objectivists, but I wonder are there people who went the opposite way?
I think I will be the subject and AB format. 10 trials?By whom, and using which test format?
A lot of potential non-auditory cueing. I’d look at a sorting format. Sufficient trials to get you to better than 5%.I think I will be the subject and AB format. 10 trials?
I think on IOS, nonplaying DAC has to be physically off. I will need to fashion an opaque shield that will hide the DAC from view.
I will also need to show my wife how to turn the DACs on and off and how to use the switch box.
What is a sorting format?A lot of potential non-auditory cueing. I’d look at a sorting format. Sufficient trials to get you to better than 5%.
Before getting fancy, do a level matched comparison. You may be surprised.
That is not sufficient to determine level matching. You have to measure the outputs with identical signals and match to 0.1dB.What is a sorting format?
And it turns out that my Liberty and M2TECH output 5v from their balanced analog outs.
I only have a digital voltmeter. That's probably not enough - I will need to clearly distinguish 5 vs. 5.06 volts.That is not sufficient to determine level matching. You have to measure the outputs with identical signals and match to 0.1dB.
Voltmeter will likely work fine.I only have a digital voltmeter. That's probably not enough.
I do have one of those calibrated microphones that plug into your phone and work with audio apps. But I don't think it's dependable to 0.1 dB.
Will give it a try! 1 KHz tone is the common test point?Voltmeter will likely work fine.
Centered on 1KHz?pink noise may be better
I need to locate my test CD, I think it has pink noise and 1/3 octave white noise, if memory serves.Pink noise isn't centered--it covers the entire audio spectrum. But it is random noise, so the reading may wiggle a bit.
But 1KHz will also work fine, and it will not likely explore the bandwidth of the AC-reading part of your DVM.
It's not important that the reading is really accurate, but rather that it's repeatable so that matching the devices under test will really match them.
If you use a DVM make sure it is a true RMS-reading meter. Most better ones are if they claim to be. Most can read power properly, but the meter needs the bandwidth to read 1000 Hz, not 60 Hz.
Rick "who uses an old Trio SSVM for this task" Denney
I don't think this is true at all. Since at least the 1970s, any mass-market receiver, run below clipping, has been sonically indistinguishable from the most expensive amp/pre-amp combinations that were properly designed for flat frequency response and low distortion (which includes almost all solid-state products and many tube products). And DACs in CD players have been sonically perfect since the very first Philips player (which I owned).
It was JA, he includes that story in a column Who Watches the Watchers? The overall subject matter is relevant here.One of the Stereophile guys said he did for a while, but he was miserable so he shifted back. I don’t remember if it was Atkinson, who is here on ASR from time to time. Or maybe Holt.
How old is "older"?Many of those older receiver / amps had rising often significant distortion at high frequencies. You will note it is rare to find specs from that age with distortion measured anywhere but at low frequencies.
