I've never seen current mode used for audio.
I have been told that the 25kV really really hurts.
Sounds like a woo-woo myth.Yes, but allowing some transient headroom?
My father got shocked regularly working on TVs. My recollection of these events (when it happened in his shop) was that he'd typically be jumpering across suspect electrolytics with a test capacitor, and he'd accidentally brush across a hot, uninsulated wire or connection. Invariably he'd call the TV a remarkably insensitive name (not profanity -- worse, in the 1960s when certain terms were much more commonly used than today) and yank his arm out very quickly. The damage he would suffer, invariably, was a scratch, cut, or gash on the arm caused by some sharp bit of chassis or cabinet.
Such are the memories of my youth.
EDIT: Oh, I think the projection TVs had anode voltages of ca. 30 kV. Forgot to mention that.![]()
Yeah, it works. In most systems it takes a special voltage-to-current converter. Must be sold for super noisy environments.This?
Krell CAST – Current Audio Signal Transmission Product Overview – Krell
www.krellhifi.com
I've got some here!
OPT works in a way similar to a transmission in a car--converting low torque high rpm engine turns into high torque low rpm wheel turns.Valve amps typical put out high voltage and low current, so the load needs to be high impedance, while speakers need low voltage and high current, so there low impedance. The output transformer converts the first to the second. It transforms the low impedance to high.
Uh oh, the dreaded car analogy!OPT works in a way similar to a transmission in a car--converting low torque high rpm engine turns into high torque low rpm wheel turns.
What's dreaded about that analogy? Is it just because it's overused, or is there some other reason? As a retired E.E. who, with a colleague, has a patent on an output transformer for vacuum tube amplifiers, I actually am aware of the limitations of that 'tire'd' (oops! another car-word!) transformer-transmission analogy, but it does sort of get the idea across, especially for non E.E. tube enthusiasts just getting into the hobby. A bit worn around the edges, though, it certainly is. The treads on that tire are so thin that you can see the air inside.Uh oh, the dreaded car analogy!![]()
Another solution to a problem that dosnt exist. And the liars contradict themselves.This?
www.krellhifi.com
I've got some here!
Choke input or pi filter between plate and screen nodes? They both make sense, but...He prefers choke power supplies for single ended valve amps. Now that one I can understand may be a benefit, effectively being a choke load on the anode and delaying the point at which the output would clip as signal rises.
