Audio Technica AT-OC9XML
Helicopter
Michigan
The MM vs MI vs MC thread is getting a bit long, and covers several subtopics on measurements, so I am making this thread to focus on the cartridge I got when I took interest over there.
First, I figured a microscope inspection would be a good predecessor to ripping sweeps for measurement. Here's how my AT-OC9XML looks right now:
Obviously, my theory that the silver stuff around the stylus tip was protective packing grease or something like that was incorrect. It hasn't changed much with a couple hundred hours of break in and corresponding cleaning with melamine foam and a carbon fiber brush... anyway, looks clean enough, so time to rip some tracks and see if I can process them into useful data.
DSJR
Suffolk Coastal, UK
I was sad the previous At F2 and F7 had been discontinued, as I fondly remember the old and rather 'wild' F3 and F5 of old. Makes sense to use one basic boddy and generator for different stylus types which they've done so well with their VM95 and VM5**/7** ranges. Apparently, the sub £300 OC9XEN is a goodie and I bet the bonded elliptical ain't too shabby either.
AT aren't always the neatest in applying adhesive, but the diamonds usually seem good however. I have here an OC30 (more 'balls' than the old OC9's had) where the butt-mounted diamond has been knocked off, leaving a quantity of adhesive not so different to yours..
As for run-in, the old models asked for 1.5g tracking. I found that 1.7g or so for the first few album,s and then reducing to 1.5g as recommended then helped no end. Modern ones are 2g, so no idea now...
Helicopter
Helicopter
Michigan
I went straight from a Technics SL-1200 MK5 to a Focusrite Scarlett 2i2, with a Neutrik NC-MX RCA-XLR adapter and no phono preamp. I recorded the left channel only with CBS Test Record STR-100 track A1A left channel sweep, deleted everything before and after the sweep, and exported it as a signed 16-bit PCM .wav, which required down sampling and converting to stereo. That raw .wav file is published here.
JP
Brookfield, CT
Tom C
Wisconsin, USA
Is a distortion analysis possible?
I’m surprised by the spectrum analysis. I would have expected a rising high frequency response, especially without RIAA correction.
I was too slow. JPJ has already posted...
Balle Clorin
I took your file and compensated for pink noise slope and NO RIAA above 1 khz, constant velocity. Suspicious that right and left channels are identical when I tried to import to REW
JP
Brookfield, CT
STR-100 sweep tracks are constant velocity from 500Hz. The 2i2 isn't going to load the cartridge right, so there will be some difference from that.
Balle Clorin
Compared with my ATOC9 mkII/ML and Elipson test record sweep with 500R-0 eq, 200 ohms, and converted to linear RTA plot. Testrecords are likely to differ, see bottom plot
Helicopter
Helicopter
Michigan
Thanks! Interesting. Agree loading is off. Here is another raw recording with de-emphasis straight from my 100 ohm 180pF NAD PP2.
Would I need to buy Matlab to get Anaconda/Python to make the charts or am I just formatting the file names and locations incorrectly?
Code:
PLEASE READ
To use this script you need to edit HOME to the directory where the .wav file is.
The .wav file can be any monotonic frequency sweep either up or down in frequency but
it must be trimmed at both ends to remove any leading silence. Frequencies below 1kHz are
ignored since virually all cartridges are well behaved below 1kHz.
Python does not read 24bit packed .wav's 16 bit is more than enough here.
The info_line should be alpha-numeric with entries separated by " / " only.  The script
will save a .png file that is named from the info line, replacing " / " with "_".  As
example "this / is / a / test" will create a file named "this_is_a_test.png"
from scipy import signal
from scipy.io.wavfile import read
import matplotlib.pyplot as plt
import numpy as np
import datetime
import os
#edit here to add a HOME directory, etc.
HOME = 'Users\16073\Documents\Audacity'
_FILE = 'oc9xml.wav'
info_line =  'oc9xml'
#end edit
try:
    input = raw_input
except NameError:
    pass
#_FILE = input('Enter a .wav file (no quotes): ') #file needs to be >= sec_per_rev*2
#Needed to steal Matlab's flat top window
def ft_window(n):
    w = []
    a0 = 0.21557895
    a1 = 0.41663158
    a2 = 0.277263158
    a3 = 0.083578947
    a4 = 0.006947368
    pi = np.pi
    for x in range(0,n):
        w.append(a0 - a1*np.cos(2*pi*x/(n-1)) + a2*np.cos(4*pi*x/(n-1)) - a3*np.cos(6*pi*x/(n-1)) + a4*np.cos(8*pi*x/(n-1)))
    return w
try:
    input = raw_input
except NameError:
    pass
#_FILE = input('Enter a .wav file to process ')
#File needs trimming with no leading or trailing silence (undefined f)
y = read(HOME + _FILE)
Fs = float(y[0])
input_sig = y[1]
frequency = []
amplitude = []
frequency2h = []
amplitude2h = []
frequency3h = []
amplitude3h = []
freqout = []
ampout = []
freqout2h = []
ampout2h = []
freqout3h = []
ampout3h = []
F = int(Fs/100)
win = ft_window(F)
#For Fs sampling use small Fs/100 FFT's so frequency is f/100
#All common sampling rates are divisible by 100
#First try, no overlap and flat top window
#Find the minimum and maximum frequencies and flip the data if the sweep
#is going down in frequency.
y = abs(np.fft.rfft(input_sig[0:F]*win))
minf = np.argmax(y)
y = abs(np.fft.rfft(input_sig[len(input_sig)-F:len(input_sig)]*win))
maxf = np.argmax(y)
if maxf < minf:
    maxf,minf = minf,maxf
    input_sig = np.flipud(input_sig)
for x in range(0,len(input_sig)-F,F):
    y = abs(np.fft.rfft(input_sig[x:x+F]*win))
    f = np.argmax(y) #use largest bin
    if f >=10:
        frequency.append(f*100)
        amplitude.append(y[f])
    if 2*f<F/2-2 and f >= 10:
        f2 = np.argmax(y[(2*f)-2:(2*f)+2])
        frequency2h.append(f*100)
        amplitude2h.append(y[2*f-2+f2])
    if 3*f<F/2-2 and f >= 10:
        f3 = np.argmax(y[(3*f)-2:(3*f)+2])
        frequency3h.append(f*100)
        amplitude3h.append(y[3*f-2+f3])
amp = 0
count = 0
x = minf*100
for x in range(minf*100,(maxf+1)*100,100):
    for y in range(0,len(frequency)):
        if frequency[y] == x:
            amp = amp + amplitude[y]
            count = count + 1
    if count != 0:
        freqout.append(x)
        ampout.append(20*np.log10(amp/count))
    amp = 0
    count = 0
amp = 0
count = 0
x = minf*100
    for y in range(0,len(frequency2h)):
        if frequency2h[y] == x:
            amp = amp + amplitude2h[y]
            count = count + 1
    if count != 0:
        freqout2h.append(x)
        ampout2h.append(20*np.log10(amp/count))
    amp = 0
    count = 0
amp = 0
count = 0
x = minf*100
    for y in range(0,len(frequency3h)):
        if frequency3h[y] == x:
            amp = amp + amplitude3h[y]
            count = count + 1
    if count != 0:
        freqout3h.append(x)
        ampout3h.append(20*np.log10(amp/count))
    amp = 0
    count = 0
b, a = signal.iirfilter(3,.5, btype='lowpass') #filter some noise
ampout = signal.filtfilt(b,a,ampout)
ampout2h = signal.filtfilt(b,a,ampout2h)
ampout3h = signal.filtfilt(b,a,ampout3h)
norm = ampout[0]
ampout = ampout-norm #amplitude is in dB so normalize by subtraction at [0]
ampout2h = ampout2h-norm
ampout3h = ampout3h-norm
f, plt.figure(figsize=(14,6))
plt.semilogx(freqout,ampout,color = 'b')
plt.semilogx(freqout2h,ampout2h,color = 'g')
plt.semilogx(freqout3h,ampout3h,color = 'r')
plt.grid(True, which="both", axis="x", ls="-", color="black")
plt.grid(True, which="major", axis="both", ls="-", color="black")
plt.grid(True, which="minor", axis="both", ls="-", color="gainsboro")
#plt.grid(True, which="both", axis="x", ls="-", color="black")
#plt.xaxis.grid(True, which="minor", ls="-", color="gainsboro")
plt.minorticks_on()
plt.title("Instantaneous Frequency vs. Amplitude and Distortion: "+ _FILE + "\n", fontsize=16)
plt.xlabel("Frequency (Hz)")
plt.ylabel("Amplitude (dB)")
plt.figtext(.17,.7,'- 2nd harmonic -',color = 'g')
plt.figtext(.17,.67,'- 3rd harmonic -',color = 'r')
plt.tick_params(which='both',
                top='off',
                left='off',
                right='off',
                bottom='off')
mod_date = datetime.datetime.fromtimestamp(os.path.getmtime(_FILE))
plt.figtext(.17, .13, info_line + "\n" + \
            mod_date.strftime("%b %d, %Y %H:%M:%S"), fontsize=10)
plt.savefig(info_line.replace(' / ', '_') +'.png', bbox_inches='tight', pad_inches=.75, dpi=96)
#plt.show()
JP
Brookfield, CT
Don't need to buy anything. Just need Python and to install the libraries (matplotlib, scipy, and numpy). The latest version of the script *should* be OS independent, but I've not tried it on Windows.
Helicopter
Helicopter
Michigan
I made a mono recording, left channel only, and then when I convert it to wav it gets down sampled and converted to stereo.
JP
Brookfield, CT
Code:
PLEASE READ
import numpy as np
import datetime
import os
#end edit
try:
    input = raw_input
except NameError:
    pass
def ft_window(n):
    w = []
    a0 = 0.21557895
    a1 = 0.41663158
    a2 = 0.277263158
    a3 = 0.083578947
    a4 = 0.006947368
    pi = np.pi
    return w
try:
    input = raw_input
except NameError:
    pass
Fs = float(y[0])
input_sig = y[1]
frequency = []
amplitude = []
frequency2h = []
amplitude2h = []
frequency3h = []
amplitude3h = []
freqout = []
ampout = []
freqout2h = []
ampout2h = []
freqout3h = []
ampout3h = []
F = int(Fs/100)
win = ft_window(F)
minf = np.argmax(y)
maxf = np.argmax(y)
if maxf < minf:
    if f >=10:
amp = 0
count = 0
x = minf*100
            count = count + 1
    if count != 0:
        freqout.append(x)
    amp = 0
    count = 0
amp = 0
count = 0
x = minf*100
            count = count + 1
    if count != 0:
        freqout2h.append(x)
    amp = 0
    count = 0
amp = 0
count = 0
x = minf*100
            count = count + 1
    if count != 0:
        freqout3h.append(x)
    amp = 0
    count = 0
norm = ampout[0]
plt.minorticks_on()
                top='off',
                left='off',
                right='off',
                bottom='off')
#plt.show()
That's an older version of the script. Home is in Mac/UNIX directory nomenclature. I also had to trim the first ~7 seconds off your file as the amplitude was too low there.
DSJR
Suffolk Coastal, UK
That response looks ok to me. A dB or two lift over 10khz seems a feature of modern far eastern cartridges except those intended for vintage audio people. I was told once that Japanese vinyl had a softer compound and maybe softer highs as well, which is why many japanese cartridges liked a lifted hf and in older models, a steeper diamond rake angle not really fixed with VTA adjustment.
Helicopter
Helicopter
Michigan
This code:
Code:
import numpy as np
#HOME = "/home/david/"  #Linux example
HOME = 'C:\Users\16073\Documents\Audacity\' #Windows example
#edit here for 45 rpm samples
Period = 1.8 # 33rpm
#Period = 4/3 # 45 rpm
#end edit
def instfreq(sig,Fs):
    z = signal.hilbert(sig)
    rawfreq = Fs/(2*np.pi)*np.diff(np.unwrap(np.angle(z)))
    rawfreq = np.append(rawfreq,rawfreq[len(rawfreq)-1])    #np.diff drops one end point
    b, a = signal.iirfilter(1,100./(Fs/2), btype='lowpass')
    a = np.convolve(a,a) #make an ordinary 100Hz 4 pole filter.
    b = np.convolve(b,b)
    instfreq = signal.lfilter(b,a,rawfreq)
    return (instfreq)
_FILE = input('oc9xml.wav') #file needs to be >= 4 sec.
Fs = float(y[0])
if np.size(y[1][0]) == 2:
    sig = y[1][:,0][0:int(Fs*4)] #Grab 4 sec of a stereo file from the first (left?) channel
else:
    sig = y[1][0:int(Fs*4)] #mono file
t = np.arange(Period,0,-1/Fs)  #Reverse time (theta axis)
theta = t*2*np.pi/Period   #Time becomes degrees (Periodsec = 2pi radians)
theta = np.roll(theta,int(Fs*.45))  #Rotate 90 deg to put 0 on top (Period*Fs/4)
freq1 = instfreq(sig,Fs)
glitch = 2000   #remove leading glitch from output (probably should depend on Fs)
if1 = freq1[glitch:glitch+int(Fs*Period)]
if2 = freq1[glitch+int(Fs*Period):glitch+int(2*Fs*Period)]
maxf = int(max(max(if1),max(if2))+.5)
r1 = 20.-(maxf-if1)/3.  #20 radial ticks at 3Hz is fixed, adaptive scaling
r2 = 20.-(maxf-if2)/3.  #is an exercise for later
ax = plt.subplot(111, projection='polar')
ax.plot(theta,r1)
ax.plot(theta,r2)
ax.set_rmax(20)
                        #Set up the ticks y is radial x is theta, it turns out x and y
                        #methods work in polar projection but sometimes do funny things
for tick in ax.yaxis.get_major_ticks():
                tick.label.set_fontsize(8)
plt.yticks(np.arange(1,21,1))
ax.set_rlabel_position(90)
myticks = []
for x in range(0,20,1):
    myticks.append(str(maxf-57+x*3))
ax.set_yticklabels(myticks)
ax.set_xticklabels(['90'+u'\N{DEGREE SIGN}','45'+u'\N{DEGREE SIGN}','0'+u'\N{DEGREE SIGN}',\
                    '315'+u'\N{DEGREE SIGN}','270'+u'\N{DEGREE SIGN}','225'+u'\N{DEGREE SIGN}',\
                    '180'+u'\N{DEGREE SIGN}','135'+u'\N{DEGREE SIGN}'])
ax.grid(True)
ax.set_title("Instantaneous Frequency  "+ _FILE, va='bottom')
plt.show()
spits out this figure now:
I guess that's an improvement. :D
JP
Brookfield, CT
That's the polar plot code, not the FR code.
JP
Brookfield, CT
JP
Brookfield, CT
This is an inverse RIAA filter you can use in Audacity to remove EQ when recording with your phono stage. Select the audio, go to Tools, Nyquist Prompt, and enter this. Also check the v3 syntax box. It's for 44.1 sample rate only.
Code:
(biquad-m s 7.424809e+000 -1.285961e+001 5.448569e+000 1.000000e+000 -9.311757e-001 0.000000e+000)
Helicopter
Helicopter
Michigan
Code:
This works fine for me, but I can't get the script to work in Anaconda. I ran
conda install matplotlib
conda install scipy
conda install numpy
and all they all went through without erroring out. However, that polar plot code is the only thing I have been able to get to generate anything.
