In Portuguese "ri alto" means "laughed loudly". Very fitting. This amp had a good potential but just failed to deliver.
It could be a Class D design, but AudioControl mostly uses Class H topology in their amplifiers. This compact design deviates from their full-sized amplifiers in a lot of ways, so they may have gone with a "chip" amp to meet this form factor. The Rialto belongs to me, incidentally.I assume there's a class D module powering this?
Lucky panther keeps his head.
I wonder how many pages will this thread have.
PS- How is the member's reaction that has lent it?
My understanding is that this model, the Rialto 400 and Bijou 600 are all based on the same internal design. They use Hypes UcD250LP Class-D modules along with an Audiocontrol proprietary analog tracking power supply. Reading this review raised some concerns to me, but I have been happily using it for about 4 years now powering inefficient speakers from Dynaudio and Eminent Technology. To my ears, this amplifier was a dramatic upgrade to similarly powered amplifiers using ICEPower modules.I assume there's a class D module powering this?
The frequency response can be corrected via the remote control.That frequency response definitely has audible consequences. How it interacts with room modes though, would be difficult to untangle.
Wondering if you find that turning the Accubass off has any impact on the distortion and noise figures previously posted. It is weird that the Niles amplifier tested on ASR was significantly better. It uses the same Hypex UcD250lp modules as the Rialto. Maybe the larger internal space in the Niles is better for this. Either that or maybe the power supply in the Rialto has an impact here.The frequency response can be corrected via the remote control.
The peak you see early in the FR is caused by the "AudioControl AccuBASS" "feature". You can turn it off via pressing the AccuBASS button on the RC.
I'm currently evaluating the Rialto 600 and my measurements and impressions match yours ( I too had that bump in the freq. response, but got it straightened by turning off the AccuBASS using the RC ).
The figures are lower with AccuBASS disabled, but not significantly I'd say ( a 0.025% drop or so ).Wondering if you find that turning the Accubass off has any impact on the distortion and noise figures previously posted. It is weird that the Niles amplifier tested on ASR was significantly better. It uses the same Hypex UcD250lp modules as the Rialto. Maybe the larger internal space in the Niles is better for this. Either that or maybe the power supply in the Rialto has an impact here.
Audio Control used Hypex UCD250LP modules for this design, I believe they are good class-d modules. These are fairly cheap modules today, but not when the amplifier was brought to market. I wonder if the modules weren't placed too close in the enclosure causing the higher distortion figures. The Niles amplifier reviewed own ASR using the same modules did much better.
Yeah. If only they had used a Hypex NC252MP... I'm sure whatever they actually used was a lot cheaper.
