Audio Buffer – unity gain link stage/headphone amp with ultimate output drive capability
pma
pma
Prague
What does it look like into say a 10 k load plus a small capacitance?
Virtually same as into 1Mohm.
I placed the PCB to the Modushop box to make a headphone amplifier.
Edit: 115kHz square response + rise/fall time added
pma
pma
Prague
I made a measurement with RightMark SW, a comparison between Topping D10s-E1DA Cosmos loopback and the same with the Audio Buffer inside the loop.
Frequency response
Noise level
Dynamic range
THD
IMD
Crosstalk
We can see that the Audio Buffer makes no audible degradation. If we explore THD spectrum of individual measurements, then with Audio Buffer inside the loop we have cleaner spectrum with much less high order harmonic distortion components. This because the output stage of the Audio Buffer is able to give much more output current and operates at higher idle current than the output opamp of the D10s DAC.
restorer-john
The in band ripple is more than I would expect. I presume it is the D10s.
Nice buffer Pavel. :)
Reactions: pma
pma
pma
Prague
Thank you :).
The in band ripple is mostly from D10s, but also from E1DA. We pay for the very steep filters in both devices, the price of almost no mirror images.
Even more ripple for 44.1kHz Fs.
Buffer open photo (as tested)
