Several months ago I built and installed 4 bass traps to my living room, each of them sizes W60cm x H72cm x D10cm.
I only used variable smoothing when I measured my speakers (ELAC DBR62) when I installed bass traps, and thought that they made some positive changes.
I posted FR graphs on reddit and at least some people thought the same.
But was var smoothed graph a good choice for this?
Later I learned that ERB (or Psychoacoustic) smoothing might be closer to what I hear with my ears.
With ERB smoothing, sharp dip at 100Hz disappears. Does this mean that var smoothing is too much detailed, and there was not much to fix in the room to start with? Or Is the ERB smoothing too much for this case?
With ERB anything below 30Hz disappears. Var and Psychoacoustic smoothing doesn't.
Aside from that, if I remember correctly my traps reduced peaks when I'm not in main listening position. I only tested this with my ears though.
I've found amir's post saying that velocity based bass traps can't fix room modes and few people have actually made effective changes in their room.
You may not need those in larger rooms, but what about small rooms like mine? My room is very small (W2.9m x D2.56m x H2.4m), and dips are at higher frequencies (80 - 100 Hz), which could be reduced with not so thick 10cm (= 4 inches) bass traps.
At lower frequencies velocity based traps might be impractical since they need to be super thick and visually intrusive.
audiosciencereview.com
As I bought a AVR with Audyssey MultEQ XT32 recently, I've also tested with/without Audyssey today. I didn't have a receiver with Audyssey when I built bass traps.
I used following settings.
I've also attached mdat files in case if you want to see measurements in a different way.
How NOT to set up speakers and room treatment ( Goldensound)
if the mods think this isn’t appropriate please remove. it just irks me that this guy is 24 years old , this is his FIRST room with speakers and he made a video on it. and it’s a bunch of BS. his room has an RT60 of 250ms. its a room NOT headphones. he shows an impulse response and...
- Apply corrections only in 40Hz - 500Hz range
- Applied Harman target curve from https://www.audiosciencereview.com/...ker-target-responses-in-csv-txt-format.16401/
- No MRC and HF rolloff
