Anyone who uses the a1h 7.1.6 channel, please help me....
This is the Dirac measurements file for my room. (DLBC)
FL and FR are at the same distance
Impulses are measured differently due to reflections.
The reflection prediction point was covered with a 50T trap.
And at Dirac it was measured successfully.
The impulse difference between FL and FR seems to be around 0.04 to 0.08 ms.
There is a problem.
If you save the measurement file to A1H,
The impulse difference between FL and FR varied to 0.6 ms.
Even if you initialize a1h, the same thing happens if you apply a filter file.
Unless I did something wrong,
Is there anyone who can test it with a1h 7.1.6 channel?
Is there anyone who can test it on a1h with the file I attached?
I have attached the files together.
drive.google.com
There is a problem.
240101 0,04imp 1p bm ddrc88a sub (2).liveproject
drive.google.com
