Agree with this but no need for all BOLD typeEven in 1997 Fremer was like he is today.
140w/monoblock. That must feel nice in hand when dialing up a volume level. What year are yours?
What is the speaker impedance that you do this sort of high volume cranking it stuff with?I bought this pair I think around 2001 or so. Second hand. So I don't know exactly how old they are. (I'm sure tracking down info using serial numbers could tell me, but I've never bothered).
I actually recently sold a second pair of Premier 12s I had for a while. That pair was a bit newer, had been fully serviced and "upgraded" with "better parts" by CJ in 2009. They were a gorgeous, pristine pair, and I liked that they were probably in better condition than mine. Still, I ended up selling those new ones instead of my old ones as planned, as I needed the money.
When I had the Bryston amp I would crank music really loud with both the Bryston and the CJ, including to "filling the whole house" sound levels. I didn't perceive any lack in the sound with the CJ vs the Bryston even when pushed pretty hard.
Is that with the KEF woofer?Thiel 2.7
It destroys there superhearing.Well they are hurling Bible quotes at each other on S-Fool now:
Genelec G Three active loudspeaker
My review samples of Genelec's G Three powered loudspeaker came with a little hand-sized green and tan cardboard card featuring a poem in bold black letters dated 1898: At the cottage window a little bird sang. And the light of the window did flicker. And look. The roof up it sprang and the...www.stereophile.com
Objectivism is like Kryptonite to them for some strange reason.
In St. Peter we trust.
Their woofers' similarity caused a whole lot of opinions and rumors that went on for some years. I ran the KEF version for awhile. It had bass and sounded good.Thiel's drivers were made in-house.
The last design of their coax drivers, with the "flat/corrugated" midrange, were fascinating and (to my ears) extremely successful. It's the most coherent sound I think I've heard from a dynamic speaker from the mids to highs.
I have the Theil 2.4 which have the KEF or KEF-like woofer. Those woofers were around in 1980 and KEF sold them as components. I built some nice sounding speakers with them and KEF mids and tweeters. By the way my Audio Research CA-50 (tubes, 50 w/ch) runs them fine, although lacking a smidgen in bass, compared to my YBA Integre DT. 2.4 Specs are almost identical to ones Matt listed for the 2.7's.Their woofers' similarity caused a whole lot of opinions and rumors that went on for some years. I ran the KEF version for awhile. It had bass and sounded good.
I experienced the same in 1988 when I listened to an Audio Innovations 25Wpc tube amp and an Amber ST70 solid state amp. I think it's due to higher distortion in the output transformer of the tube amp which generates more harmonics and probably also IMD which increases quantity (more bass) but decreases sound quality.FWIW: One thing that stuck out to me when replacing the CJ with the Bryston was an apparent cleaning up of the sound around the sub-bass/bass.
So for instance some orchestral spectaculars I have listened to for a long time had moments where the double bass, low brass, lower woodwinds are all swirling around the same range, and there would be some muddiness with the CJ amps. The Bryston seemed to "grip" the speakers better so that those passages didn't sound muddy and the instrumental lines playing near the same bass region in complex passages were more separated and discernible. This seemed to be the case on both speakers, and at whatever volume level. So the "easier to drive" impedance of the Joseph speakers didn't seem to help that much. My layman's impression is that there is a deficit in the CJ tube amps performance that I don't seem to be able to tie directly to the differing impedance/sensitivity of the speakers. But I'm just some mook, so...ya get what ya paid for.
Well if there were no differences in 1997, why would there be now?1997 was a long time ago
Of course this is quite general, there can of course be differences but there is always a measurable reason why;...the evidence would seem to suggest that distinctive amplifier sounds, if they exist at all, are so minute that they form a poor basis for choosing one amplifier over another. Certainly there are still differences between amps, but we are unlikely to hear them.
The other factor is the high output impedance of tube amps which leads to higher output at the impedance peaks of the speaker. Since those are usually around the resonance of the woofer (one or two peaks) it also adds quantity and looses quality.
Hey Matt: I struggle to type as my brain to keyboard is kind of disconnected and it looks like you are completely wired in that regard so I need to be brief. I do enjoy how much and the insight, depth, vigor and speed with which you contribute on this website.I didn't know there could be any connection between a KEF woofer and the Thiel 2.7 woofer.
Yes, the oval driver is a passive driver. Sorry I thought you'd been referencing the white woofer. I have no idea where that oval passive comes from, so maybe not in-house.Not sure but the large oval driver may not be a driver at all on the 2.4 and 2.7 but a passive radiator. Just guessing, because the guy at DB Audio in Berkeley CA where I bought them in 1980 for my own design said that the were often used for that. I used them as driver and they still sound good at my brothers house.
Back around 2000? I bought the 2.4's to use with my Nakamichi System One and after that went on a search for a new amp and reduced it down to Audio Research CA-50 $3.5K and and YBA Integre DT $2.5K. I liked them both wanted to save $1000 and always thought the CA-50 had a much more revealing mid-range. Ten years later when I saw a used AR CA50 I snapped it up and have swapped it back and forth with the YBA. The solid state YBA has much more control of the LF and I think low powered tube amps have this issue especially with 4 ohm loads. My son will get the AR CA50 for his 30th birthday as promised in a few years.
Keep posting and would love to see Amir test a higher powered flagship AR, CJ, Lamm etc. tube amp
I don't think a comparison with medicine is valid. Hi-fi is just a hobby in which we indulge ourselves, medical treatment is, or can be, life and death.This discussion (Archimago, ASR, Stereophile) are all a reflection of the debates currently in Western Societies. That is, should we abandon facts and evidence? And replace it with religious belief and superstition? This argument is no longer limited to hifi. It appears in debates over politics, science, medicine, sociology, public health, environmental science, etc. It follows the rise of radical political ideologies.
A simple example would be: if you or a loved one became seriously ill, would you choose...
evidence based medicine or thoughts and prayers?
This is not meant to be a political statement (I am a physician) and I agree with Christopher Hitchens.
In the 1980s I built a DIY speaker based on a Kef design using the B139B, that is the oval driver. AFAIR Kef offered a passive version as well (no voice coil) which looked similar to the active version.Yes, the oval driver is a passive driver. Sorry I thought you'd been referencing the white woofer. I have no idea where that oval passive comes from, so maybe not in-house.
I think the juxtaposition is very relevant. Of course the effect in the medical field is more deadly than in audio, but the widespread denial of settled science, be it in audio, on climate change, vaccines or various dangerous forms of alternative "medicine" all undermine the methodological standard we as humans have successfully developed to distinguish truth from falsehood. That methodological standard applies across the board, so abandon it in one area, and there is no longer a reason to apply it anywhere. The trend seems to come with a blurring of the distinction between facts and opinions, as if facts are just opinions and thus can be equally personal, and deserving of democratic respect.I don't think a comparison with medicine is valid. Hi-fi is just a hobby in which we indulge ourselves, medical treatment is, or can be, life and death.
