mononoaware
- Joined
- Apr 6, 2021
- Messages
- 816
- Likes
- 669
For me, both toslink and analog work flawless on 7.6.x firmware and both have those crackles/static on 7.8.x, so the issue my files above show there are issues with the analog output as well. That crackling is much more noticeable on some music via headphones.
That is a concern if the analog output is affected as well.
I am pretty sure the A1392 is officially no longer supported by Apple (they are distancing themselves from it and want you to think of it as a non-apple device).
To be fair I have only listened to the A1392 through speakers, edit: and always used an iOS device (phone) to AirPlay to the A1392.
And when I tested the analog output I just listened to a few songs for about 15 mins, and since the severe "glitches" of the optical output were simply not there I did assume at the time that it was working perfectly.
Even if I had another DAC to try it with, based on previous experience with the extremely poor jitter performance I would expect sub-par performance in general and would rather get rid of the A1392.
It may be audibly flawless for you on 7.6.x firmware, but measurements of the A1392's optical output with the most recent firmwares would likely show poor results (basically I think your DAC is doing a decent job of re-clocking the jitter).
From memory, the "flawless" old firmware started with a 6.x.x.
With a company the size of Apple, you'd expect them to have a rigorous test setup for software releases that would catch these things. It's a real shame, since with good firmware, it's a great device; frustrating that they're so close.
My suspicions now lie towards the dual "3.5mm analog + Mini-toslink" output component.
If the issues have small variances with the output (both optical and analog), I think the "quality" of the component in question was poor and its performance is affected by minor changes in the firmware.
Try using the analog output on 7.8.x with some solo piano music and listen via headphones. I'm curious if playback would be crackle free for you (if possible, try with the song I linked above).
Maybe I would hear the "crackling" if I listened with headphones, I would say the chances are high since the optical output had severe issues but I have already "Factory Reset" the A1392 and it is sitting in the closet waiting to be given to someone.
My experience is the A1392 is "broken" with optical (with all available firmwares) so I have very little interest in setting it up again. . .
The issue with optical output was severe, I would experience "gaps" every 10-20 seconds and the parts that would play would be full of obvious artefacts.
The issues with every available firmware I tried were exactly the same (no improvements and no degradation).
