AetherDrive
- Joined
- Dec 6, 2022
- Messages
- 9
- Likes
- 11
I've went the DIY route and built myself a 4-way active speaker and for the most part I've been pretty happy with it with the exception of the amplifiers running it. I was originally running the system with an AVR (Marrantz SR7008) Direct In and found that at moderate volume it will audibly clip, it also has a buzz which is audible on the tweeter during quieter passages. Recently I got the Fosi V3 to handle woofers and it was nothing short of transformative, the increase in headroom and just overall performance leaves the AVR in the dust and now I'm looking at getting three separate amplifiers to fill out the rest of the channels and retire the AVR. The main reason I'm not getting 3 more V3s is that on power down it has an audible pop and I'm worried that my lower power rated drivers, 15-20 watts RMS, won't be able to survive that as I do turn off my system when I'm not using it. I was also hoping that for the other 3 channels I could spend a little more, up to $200, to get a little bit better performance than the V3. I've been doing quite a bit of research into this but was hoping I could get some input from the community.
