How does the ARC report look for corrected FR?I decided my SVS Pro 1000 wasn't right for the AVs... so I auditioned Rel and SVS 4000... now there's an SVS 4000 in the corner....
Upgrade complete right![]()
You might find that a second (perhaps even smaller) sub somewhere else in the room can help with the bass response more. It is all very geometry and materials dependent. Though if you're happy with it as is, that's all that really matters.
Yes, this would be an option as per my last paragraph. However, the STR supports passthrough in standby. There's no need for it to be on when using the AV processor to watch a movie, hence my query.Would you not turn on the STR-Pre to then turn on the power Amp ..
Page 9 of the manual - item 10
Or am I missing something?
HTH
It does, and sounds good in pure direct. I feel that I have taken the Marantz a far as it will go in stereo.Does the Marantz AV8805 have stereo mode? Trying to understand what the Anthem Pre is for since you're using the same amplifiers.
audiosciencereview.com
There's this device which reviewed here a few weeks ago.
BobWire XLR1 XLR and RCA Switcher Review
This is a review and detailed measurements of the BobWire XLR1 XLR switcher including support for conversion from RCA. It was sent to me by the company and costs US $270. As these "problem solver" boxes go, this is very attractive packaging. The big deal though is high level of flexibility and...audiosciencereview.com
Hi folks
My STR arrives this week, and I plan on using it in HTBypass with my Marantz AV8805 and a shared power amp for L/R.
Has anyone figured out an off-the-shelf 12v trigger for this kind of set up?
I need the STR to trigger the PA when used for stereo, and the Marantz to trigger it when used for HT.
Any solutions I've found are janky at best, with some combination of motorcycle indicator signal cables and diodes to be hacked together.
I'm in no way electrically inclined, and wouldn't know a diode from a capacitor in the ground.
Surely there exists some kind of commercial 12v matrix type device for this purpose? For an extra challenge, I'm in Europe
Or do people just run the STR always on, even for HT passthrough, and let it manage the power amp trigger?
Personally, I'd try to keep it simple and just daisy chain the trigger through them all. I think the Marantz has 2x trigger out. Run that to the STR trigger in, then the STR trigger out to the amp.
I suspect if you just turn on the STR it will turn on the amp, and the marantz will be off. If you turn on the marantz, it should turn on everything. Not positive about that, but clearly if you always turn on the Marantz the whole chain will turn on, even if you're only going to use it in stereo mode.
Except STR doesn't appear to have a trigger in, from reviewing the manual anyway
I could build an automation to detect Marantz power on, or more likely just edit my IR script to power them both up at the same time.
Way overthinking this, for sure. I'll likely end up just running everything powered up. I was just going someone had come across a 12v repeater, multiplier or matrix type device that would do the trick.
That’s right, it has IR in. I misremembered the inputs. It does support automation via IP.
According to the Manuel page 13 HT bypass engages automatically even when in standby..
In regards to having the PA turn on for either the STR or Marantz, you can use a diode combiner for the 12V triggers.
I might reach out to Anthem and see what their idea of a solution might be. As stated, their bumpf does speak to HT Bypass, sharing speakers etc. etc. so it cant be an uncommon request, surely?I wonder if a 3.5mm mono y splitter would work? Single male end into amp and trigger wire from AVR and STR into female ends. If both were accidently turned on at same time would it cause a problem?
