Posting to alert members of my Topping L30 II failing due to static. I reached for the volume knob, felt static, heard a loud pop and smelled burning electronics. It dropped into failure mode with the flashing white light. The volume knob was extremely difficult to turn.
I opened the back panel and found that the grounding pin was loose in the case. I don't know if it was knocked loose in shipping 1.5 years ago or just now when the failure happened but it doesn't look burned.
I'm amazed this continues to be an issue when it was known and responded to on the previous model.
english.achoreviews.com
www.audiosciencereview.com
Topping L30 - Problems and their fixes...
English | Español Also available on YouTube in Spanish: Acho Reviews YouTube
Sequential damage
So sorry for your loss! :( I hope the company provides good customer service and compensates you for the collateral damage their product did to your headphones. Hopefully they will want to investigate what caused the problem so they can put the right safeguards in place to prevent this from...
