Amplifier with low standby power consumption
lordearl
What's a good (by ASR standards!) relatively inexpensive amplifier suitable for leaving on standby 24/7?
Matias
São Paulo, Brazil
Buckeye NC252MP stereo amp should be low power on idle.
restorer-john
When you say 'standby', what exactly do you mean? Soft switch on/off or an amplifier that will turn itself on in the presence of audio?
@boXem has audio-sense on one/some of his amplifiers, but the standby/auto power consumption would need to be confirmed by him.
Some Yamaha integrated amplifiers will turn off (standby) after a period of time and go to standby. Most of this emphasis on standby consumption is due to strict EU conditions. I believe the <1W regulation is about to become more stringent with a <0.1W requirement.
L
lordearl
Yes, sorry, I just mean on idle (soft switch) for remote IR switching on. Use case is for an office where people are coming and going all the time 24/7 so preference is not to turn it off on mains - although if the power consumption is low enough, it could simply be left fully switched on all the time I guess.
Dunring
Florida
The best combo would be the Drop THX 789 with the JDS Atom DAC which also has an auto standby mode after 15 mins. They look great together too. I had the Drop THX One version at the time too, and they sounded great.
L
lordearl
Thanks - looks like a headphone amp though, after a power amplifier for speakers if possible.
I note it would need to be singled ended rather than balanced as well, as the gear it will service is all single ended - thx in advance!
grogi.giant
I measured a couple of Aiyimas: A07, A07Pro and D03 - in BT mode were 4W, in Line-In mode were 6W. T9Pro is 10W - probably because of bright display, tubes and VU meter that are powered as well.
If it matches your low-power-in-idle criterion - I don't know.
diablo
Blackpool, England
I recently got an SMSL A300 with a built-in power supply. In standby it uses 2.3W. Idle with no signal is 5.2W. Even in use at moderate volume it rarely uses more than 6W.
