I've tried three amps with these speakers:
Cambridge Audio AXA35 was just dull.
Emotiva A-100 seemed to have a v-shaped signature that left vocals recessed. There was great detail at the low and high ends.
NAD 316BEE V2 was the opposite of the Emotiva--vocals were emphasized at the expense of detail elsewhere.
I'm pretty new to audio, but I'm guessing on the basis of my experience up to now, I'm looking for something quite neutral.
I'm wondering what other options may make sense for say under $500. I've heard some good things about the Vista Spark 2 (bummer it doesn't have a headphone jack though, 20W, but the Triangles are very efficient, so maybe this would work). I also heard about the Iotavx SA3, but it seems like a pain to order in directly from the UK (read that they were unresponsive to emails and expensive return options from US).
I will be streaming music from a computer through a DAC. If I get a DAC with a volume control (e.g., Topping E30), I guess I could consider a power amp (with no volume knob).
I'd love to learn of recommendations, especially from those who own these Triangle speakers.
Thanks--this forum has been really helpful.
Hi
There are good amps available.
Choose one with good score here, with around 100W under 4 ohm, and that will be all you need.
At least, it will remove the amp from the equation.
(I didn't check the amps you listed, maybe they are good)
Then, if sound is still not to your taste, you'll probably need to act on the room/speaker side: purchase a measurement mic (minidsp umik-1 with calibration file), measure with REW, and then check what's needed. Move the speakers a bit, re measure, check some room correction software - if it improves things dramatically, you may want a hardware correction system...
But the amp will not be the cause (nor the fix).
