I'm still unsure whether to get a more powerful amp (to supplement my RME ADI-2 DAC).
You
do not need to. But I would, and I did. My comments are
primarily based on the fact you have the ADI-2 DAC, and not the ADI-2 PRO. That said, I have the PRO, and I still added a Monolith THX887 (for reason 2 below,
not due to reason 1).
Reason 1: The headphone out power on the ADI-2 DAC will be a bit lower, and it does not support "balanced" headphone out. For anything other than a power-hungry headphone (such as the HE6SE), this reason is a total non-issue... the headphone amp in the RME ADI-2 DAC is more than enough.
Reason 2: Convenience of using multiple headphones (aka, "audiophile" first-world problems). I leave my HE6SE plugged into the 4-DIN port on my THX887, and I keep my day-to-day HD600's plugged into the RME ADI-2 DAC. And whenever I want to listen to my Focal Clears, I either just plug them into the SE slot on my TXH887 (no need to unplug the clears), or more frequently, I just swap out the HD600 for the Clear on the RME PRO.
Note: one benefit of routing to the headphone amp via a device such as the RME ADI-2 DAC / PRO is that you can use the 5-band equalizer in the RME, and just switch between pre-loaded EQ profiles depending on which headphone you are listening to... regardless of whether it is plugged into the RME or the external headphone amp.
Topping A30Pro, Thx789 and Thx887 can all be had for not very much money, and I may be tempted to get one and have a play
All would work. Personally, I have been extremely happy with the Monolith THX887; they are often now on sale around $249 (US). The A30Pro looks pretty solid as well.
I would really want a power amp, because the RME's volume adjustement has perfect channel balance.
So if I get any of the above, I am tempted to remove or bypass their volume pot, to "convert" them to a power amp.
Have any other members done that? are there any downsides to this approach? Other than losing warranty, of course?
I don't think this gains you much, if anything (pun was accidental). On the Monolith THX887, I adjust the gain switch (Level 1, 2, or 3) to put the volume into the range of what I want to listen to, so that the volume POT stays in the sweet spot of 9:00 to 3:00. For "engaged" listening to music on the HE6SE's, I usually have the gain set on 3. However, often I will want to have lower volume (Level 2 gain), and occasionally even drop the gain switch down to Level 1 when I just want background listening.
So for me, gain settings on the THX887 achieves the channel balance goal, even at the softest volumes; no need to risk screwing up a perfectly good RME ADI-2 DAC.
