One last time. I replied to robdpwx:
Listen to more live music, ideally acoustic, and ideally in a good hall. That is the baseline.
The baseline for what? What does distortion have to do with dynamic range? Have you used a modern compressor? Given the tools in a modern DAW and now semi-standard LUFS targets, you can use compressors to increase DR.
As was pointed out up thread. DR as it is commonly used is not a very good measure of dynamic range. Its is in essence biased towards classical as you are comparing the overall volume (RMS) to the loudest peak. With many pieces composers are using long stretches of pianissimo against short bursts of forte. So yeah. The measure well under that system.
I can watch the second by second the DR of any piece of music. If we measure it that way, the difference between modern recordings of acoustic and electronic disappear, in my own casual observation.
You replied to my reply to robdpwx:
Dynamic range, timbre, absolute lack of harmonic and intermodulation distortion.
The context is robdpwx’s claim that the baseline for (apparently all) critical listening to music (he didn’t specify just acoustic) is to listen to live acoustic music in many venues, so I took your statement about DR, timbre, absolute lack of HD and IMD, to be a statement that understanding those things is only possible by listening to live acoustic music. Is that not your claim?
If it is your claim, fine. I disagree. Clearly I would enjoy debating it, but we should probably take it to DMs.
If it is not, then fine, I misunderstood your point. I would be happy to discuss via DMs.
