- Thread Starter
- #41
For the K701, my best advice to you is to use the Oratory EQ, (which roly linked you already).Hello Robbo99999 and thank you for the response.
Now I only have K701, so if you have any good working eq for these cans without loosing their soundstage would be perfect.
Yes Roly answered perfectly. I am just a bit acknowledged how to use eq. I thought it was an import something so as to test eq and keep the default if you do not like a specific eq setting.
As Qobuz give as output the Wasapi exclusive to my Dac which as I read is the most preferable because does not conflict to any other sounds of pc or external audio.
And I was thinking how will the eq will work as choosing this output through my Qobuz.
Anyway I guess I have not understand something correctly!
Thank you all for your responses. Really appreciate your help!
For your choice of EQ software if using Windows & WASAPI Exclusive, then I don't think you can apply EQ system wide at the OS level, because WASAPI Exclusive is preventing that from happening. Just don't bother using WASAPI Exclusive, then you can use EqualiserAPO to apply systemwide EQ to any audio you play on your PC. If you're using a Mac, then I don't have a direct alternative for you, because I'm not familiar with Macs, but I gave you a link to all different EQ software in my previous post that covers different platforms (PC/Mac/etc).
