thanks for the reply.In my opinion the K371 is much better than the M40X.
I am sure you can find others with a preference for the M40X though..
Lovely pair of closed back. highly recommended Enjoying the faster driver response over the "old guards" ATH M50X and DT770pro.
I had the chance to test for a couple of days the AKG K371 and they sound fantastic BUT they are very delicate, the ones of my friend in few weeks are starting to have issue where they fold, it got losey and it looks like it's going to break soon.
Beyerpads and thicker armed glasses isn't the greatest combo either.
I used a headset radio in a noisy environment for work, I ended up choosing my glasses for comfort, and to a lesser extent, seal.I'm worried my glasses my prevent this from happening
IME wearing headphones and plastic framed spectacles is a complete no-no. The best have had flat metal side arms.
For me the choice of spectacles is a key issue for comfortable HQ headphone listentng.
As Solderdude has mentioned, it depends on the distance between the arms of your glasses and your skin where the pads are. Although I'm using plastic-armed glasses, the length of the arms and its curvature match my facial contours really well and as a result, I rarely experience loss of bass extension with headphones except for the rare few badly designed ones with exceptionally thin, narrow and stiff padsWell... I'm not really sure what to do about this. I can't be the only person with glasses who wants to use these headphones. Hoping someone with that experience will weigh in.
Haven't heard of such a mod, but I imagine it'd be easier to source a different cable or apply modding to the surface of the existing cableWell, I am sorry but I was too lazzy to read the whole thread. I have a question, I hope it is not answered earlier in the thread.
I own the K361 & K371. I use the K361 most of the time, and I would like to use more the K371, but it is near impossible. It's due to the fact the cable connector orientation produce a lot of friction on my shirt or whatever I wear. It is less present with the K361.
Have you heard for a mod allowing to orient the connector differently?
In fact, this is not the cable, but the whole connector + the cable connector which are too long and touch my clothes. It's a bit silly, just a different orientation should be Ok.Haven't heard of such a mod, but I imagine it'd be easier to source a different cable or apply modding to the surface of the existing cable
I'd also be happy to know of one - maybe there are some miniXLR-to-miniXLR-90deg-adapters available just to plug into the headphones?Well, I am sorry but I was too lazzy to read the whole thread. I have a question, I hope it is not answered earlier in the thread.
I've noticed many times that all kinds of reverb gets enhanced on my pair.The use of plate echo, for some reason, was fuller and more satisfying than usual.
