Aiyima A70 Mono - Leaked?
I for one have two passive subs, repurposed from active ones.
I, too, have formerly active subs with dead plate amps, as tons of others do. The question is, is Aiyima A70 Monoblock at $150 competitive with dedicated subwoofer plate/standalone amps in that price range. Also, what is the Aiyima crossover slope?
Reactions: MCH
12db.
Aiyima A70 mono - does look much better than their pics. Takes a bit to adjust to dual knob look but detailing is really good.
Bigger case work, heavier and stronger. Nothing feels cramped.
Better binding post or connectors than others.
Thanks for the reply , it 's very intresting. I' m planning to buy too A70 mono blocks for open baffle "3 way project ( 15 inch woofer, faital mids and scan speak tweeter) Maybe I could use the sub out to feed my woofers and spare some expensive passive components !?! And when you use the sub out low is a High Pass also applied also to the main outpout in order to get clean cut off between sub and speakers ?
