Advice On Streamer/DAC Combination
Bleedingears
Greetings all. I am coming to the well for some guidance. I am seeking to replace my old TEAC UD-501 DAC and a laptop that has served as my streamer and server for several years now running Foobar2000. I am experiencing intermittent dropouts when playing files from my NAS, and suspect the 8 yr old ACER laptop as the likely offending party (although the TEAC could be the cause as well). I am looking at one of several RME ADI-2 DACS, to be paired with the upcoming WiiM Ultra Audio Streamer. I am also considering the Eversolo Z8 DAC for this chore. I am assuming, hoping, that the WiiM streamer will continue the performance quality of its predecessors. Would this be a wise course of action? The package cost would come in at just over $1,000 USD. The alternative would be to bite the bullet and buy an Eversolo A8 at $900 more. Thoughts, or suggestions?
Save $900, do you even need the RME?
Unless there is a feature on the A-8 you need, personally I want the Ultra to have XLRs out.
I have the SMSL SU-1 and wiim mini. Bit perfect, sounds great, ~$200 bucks. No features though, feeding into an AVR for bass management etc. i have one bass resonance to correct, so the new 10 band para eq is 9 bands more than I need.
Usually, something is "interrupting". The operating system is ALWAYS multitasking and interrupting even if you're only running one application. There are buffers to smooth-out the playback but if something "hogs" the system for a few milliseconds too long, you get buffer underflow and a glitch.
A Windows update may have fouled-up something... There is a FREE online book about optimizing your computer for audio.
BUT, it could also be something in the NAS, or in the (wireless?) streaming.
That was a concern as well. I've read that there is not much advantage to XLR connectivity if your interconnect runs are short, as in 12" to associated equipment. Is this true?
Thanks. I was hoping to just get the laptop out of the chain. I'll study the book.
Almost certainly, mostly it’s because all the stuff I have is XLR. there are actual benefits making the earth before signal, locking etc.
I use quite a few Bluesound Node N100 (first generation) as streamers and multiroom with Qobuz, with a good DAC connected to each with Toslink SPDIF.
They go for 130€ or so nowadays (second hand, of course).
That works fine for me.
Application is good and regularly updated.
Add an RME ADI-2 DAC if that fits your budget and you'd have an excellent system, IMO.
(Avoid to use the Node for tone control, though.)
The main advantage of balanced interconnects in a home setting is immunity to ground-related noise issues (hum from ground loops, 'USB noise' with computers). Assuming everything's designed correctly of course (no 'pin 1 problem'). Some don't think this is worth the extra expense or limited choice, especially if they've never had a ground-related noise problem.
I would get the Eversolo DMP A8
It is really nice and worth the price of admission
So far, my system is all XLR, so the Wiim would be a departure.
