cedd
- Joined
- Apr 9, 2021
- Messages
- 15
- Likes
- 5
My 2020 Macbook Air's 3.5mm out is my source and I'm looking to use its lowest volume setting to conserve battery. The problem with going directly to the Bose speaker is that I get some static when I turn up its volume to comfortable levels. The Bose isn't grounded as the cord that powers it has no ground prong. Would getting a small dedicated amp be a good solution? How much power would I need to eliminate this noise floor? Would a headphone amp be enough?
Also I thought about soldering a wire from the ground of the audio cable to a ground prong that I'd plug into the ground socket of the outlet. Would that be worth a try as well?
EDIT: I'm currently using a 6ft cable. Would making a custom 1ft cable with a very low gauge be worth a try? Like a comically low gauge for a wire of that size... 14AWG or something.
