Hello,
I am replacing the power capacitors in my 1980's Advent 350 Receiver. The capacitors chosen require I increase the ampere rating on the power rectifier diodes. The OEM Diode part number is YAB-010EDI7945. I have not found any cross reference for this number so currently do not know the actual OEM Ampere rating of the rectifier diodes.
Question: What ampere and voltage specifications for the power rectifier diodes would be considered Robust (overkill) so I cover all my bases? Additionally, is there a resource that would be able to identify the specs of the OEM Diode. Thanks
