- Joined
- Jun 5, 2016
- Messages
- 2,875
- Likes
- 4,679
Why not ask Nathan to make you something that fits your size requirements?The Funk 18 inch offering would be a tad too big.
Otherwise, in the current market I like PSA's approach of using modern long throw "pro" drivers. Others may do the same but I know PSA. Big voicecoils, and neo magnets to cut down on weight. So efficiency in the upper part of its range but the motor strength and suspension flexibility to give high output after EQ using modern amplification. The approach just makes sense to me. If I were clean-sheeting I’d probably be choosing between small closed boxes with dual opposed “home” 10’s (like the driver @sigbergaudio uses) or small closed boxes with 18” “pro” woofers.
Hsu ULS15 is also a good one, and well-priced, that seems to get less attention.
