So, having set up everything, was just going to start measuring, and a strong wind appeared.
I was able to take measurements during the not so windy moments, but i'm not 100% sure it didn't impact measurements.
I repeated each measure several times, and verified they were consistence, so they should be enough for the purpose of comparing measure methods.
Tests performed:
- FF, AMT only, AMT center as reference Axis at 157.5 cm height
- FF, 12 only, 12 center as reference Axis at 161.5 cm height
- FF, AMT + 12", Measured AMT, AMT center as reference Axis at 97.5 cm height
- FF, AMT + 12", Measured 12, 12 center as reference Axis at 101.5 cm height => I think i've made a mistake here, the mic should be pointing to the AMT center, and not to the 12" (See image bellow)
- GP, AMT + 12", Measured AMT, AMT center as reference Axis, tilted using a 3.6º angle
- GP, AMT + 12", Measured 12", AMT center as reference Axis, tilted using a 3.6º angle
- GP, AMT center as reference Axis, tilted using a 3.6º angle
- GP, 12" center as reference Axis, tilted using a 4.7º angle
Some pics of the setup:
The gig for the Far field measurements
Here how i measure the 12" Far Field, i couldn't put both in the stand due to the gusts of wind that were occurring sporadically.
You can see that i used the center of the 12" as the axis, where i should have used the AMT, so i could compare it like for like, with GP measure 6)
Here the Isolated measure for the AMT GP:
Here setting the 3.6º angle for the tilt:
With the above caveats, here the measure comparison.
Notes:
1 - The SPL between both measurements (FF x GP) was very different, so the measures are SPL aligned:
- at 1kHz for the 12" measures
- at 10kHz for the AMT measures
2 - Ignore the 1.25m from the legend, the correct height for the FF measure is in the above description
3 - As mentioned before, i left the Timing Offset as 0, and then, for each measure, i executed the REW "Estimated IR Delay function".
I then used the IR window to "filter" the unwanted reflections.
AMT Isolated - FF vs GP
12 Isolated - FF vs GP
All boxes - Measure for AMT - FF vs GP
All boxes - Measure for 12" - FF vs GP
The first thing to note is that the conditions for measurements where not perfect.
Second, when looking at Erin's work, we note that even his measures do not align perfectly with the NFS.
Assuming the measures do not contain any (human) error, all methods seem to track reasonably well, and without a reference, its impossible to know which one is the most accurate.
For the task at hand, and as
@3ll3d00d mentioned, given its my first diy speaker, my knowledge limitations, etc, it would seem that any method would be able to provide good enough accuracy for a competent crossover.
As such, i'm planning to use the following methods to gather the required measures i need:
1 - For 12" and AMT, do GP measures, with box boxes, AMT near the floor, speaker tilted at 3.6º.
The reason for this instead of simply measuring the AMT and the 12" separately, is that by doing these together, it will take half of the time.
As a bonus, it might be slightly more accurate due to actual diffraction interactions.
2- Measure the 15" alone, GP measures with speaker tilted.
As mentioned before, bellow 300Hz the room will have a greater impact than the difference between measures.
If anyone would like to have a look at the mdat file to validate the data, please download the file here.
Comments, feedback, etc, will be deeply appreciated, as always
