AC noise filtering
Beirut
I've decided to run my computer system off a pure sinewave inverter acting as a double conversion UPS as my AC line voltage fluctuates a lot and I don't want to cause damage to my expensive equipment.
Now the AC waveform is a very clean sinewave as can be seen on my oscilloscope, however the inverter makes an audible high pitched buzzing sound and I'm hearing that exact same sound coming through my studio monitors.
My question is, how do I determine the frequency of this noise and how do I filter it?
solderdude
The Neitherlands
The ground connection on the PC is still hardwired to mains via the inverter so that problem isn't solved.
The pure sinewave also is not a pure sinewave but probably generated by some pulse density or width modulation + some high pass filtering.
When the base frequency is in the audible range it will not be easy to filter and on top of that may be present as common mode noise opposite the shared safety ground.
You could inform with the manufacturer at which frequency it switches. Chances are there are some inductors making the noise and that may even not be the actual switching frequency.
You need to break the groundloop. Probably the easiest way is to go balanced to the monitors or use line transformers (DI box) in the audio path.
Move the generator out of the room if you can hear it.
RayDunzl
Central Scrutinizer
Riverview FL
Send the noise to analysis software.
REW can tease out the frequencies.
Idle noise measured on an amp here:
