He’s the engineer. He said it not me. And if he says they work just as good when you place them on your ears I wonder where you got the rubbish of this seal flaw from?
You're calling it "rubbish" despite there being PLENTY of evidence to show exactly the same effects of a broken seal on other headphones. There is plenty of evidence to show that the results in this review are due to a broken seal, and should be re-tested. If this is not the case, then the test should be re-done with a seal, show the same thing and prove the assumption wrong.
As to the engineer's statement;
Soft 'on-ear' pads are unlikely to seal as well against your ear as proper over-ears are, but are still likely to be better than pads on a flatplate with a massive gap on one side.
Air pressure/seal isn't a binary "yes/no" question. Otherwise as someone mentioned previously, using glasses, or having a beard would make a lot of headphones awful. Its a scale. A submarine is waterproof. A submarine with a hole will let a bit of water in but will probably still work. A submarine with the tail chopped off isn't going to do so well.
Regardless again, the on-ear thing is rather besides the point. Most people won't have ears big enough where that will be the case, and if they do, it might be a legitimate concern.
I can't use the HEDD phone because my head is too big. That's not because the product is bad and they should've put more effort into making it work with the pads halfway up my ears, its just cause my head is too big, and I'm unable to use the product in the situation it was designed for.
Should they make it bigger? I'd say so, but I'm not going to equate a bad sound to bad performance/acoustics when its clearly a specific fitting issue.
The simple answer here that would put all questions to rest would be to test the headphones again with a proper seal. Abyss is apparently going to release their own measurements in response to this review, and if people don't trust them then it'd be good to see some others measure and share their results.
The diana's pads are quite clearly designed to fit the user's head better. As is the same on some other headphones. This will obviously create a situation where they will not fit properly on a flatplate. If you think that's a problem and that all headphones should be designed for a flatplate and not actual human ergonomics, then I hope you have some very flat cheeks.
