- Thread Starter
- #221
Whoever made that measurement doesn't own or use a Stax headphone as I have for 30 years. Stax headphones hang on each side of your ears like two speakers. They have almost no clamp pressure which yes, reduces perceived bass. But that is their charm, making them sound less boomy and as some people incorrectly call "fast."The image below shows an SR-507 with a seal (red) and improper seal (yellow).
As you can see, quite a lot of similar characteristics
You can surely clamp the hell out of them to the headphone fixture and get more bass but not compared to what you hear when you wear them normally. No way, no how they have flat bass as you are showing above. The peaky one with droop is far closer to what you perceive.
Now, if your goal is make things look good -- as in what a manufacturer would do -- sure, you would take a bungie cord and wrap around it. And put on such duct tape for good measure. That will fix up the bass for you. But will miss why we measure.
The Diana V2 has no resemblance to Stax. It has good clamp pressure and incredibly soft pads. It fit on my fixture better than most headphones I have tested. There were no visible gaps anywhere. Can you get more bass out of them in measurement? Yes, I mentioned that in the review I did. But subjective experimentation with EQ proved the measurements to be wrong. Changing the space and orientation of the headphone to increase measurement bass distorted the rest of the response.
Importantly, this headphone did not have proper bass in my listening tests. It simply didn't. To then go and get measurements that show otherwise is ample proof that the measurement is wrong -- just as the Stax ones you show above.
Bottom line, your evidence in the form of Stax measurements work against you, showing how you can produce wrong bass response.
As I keep saying, I iterate with EQ and listening tests to tie back to the measurements. Unless you do that, your measurements are not trustworthy.
