autoteleology
- Joined
- Aug 28, 2024
- Messages
- 8
- Likes
- 9
I am in the process of designing my home theatre / studio to isolate my subwoofer from my next door neighbor in my apartment, with whom I share a single wall with on one side of my room.
The thought exercise I am considering that my entire room layout hinges upon is as follows:
The plan is to use heavy industrial steel racking that spans the width and height of my apartment wall, filled from floor to ceiling one foot deep with brick, and then sealed on both sides with several hundred pounds worth of metal sheeting, with one or two layers of acoustic blankets hung from the ceiling, then placing my subwoofer against this wall and hoping that the bass reflects outwards and upwards back towards the listening position and not through the wall.
If the wall does a good enough job of reflecting sound, this should, theoretically, be a better system than having the subwoofer on the other side of the room (thirty feet away), due to the fact that the wall, being closer, should block an essentially infinite "field of view" before reflecting off the room, rather than a limited field of view of whatever the base of an imaginary pyramid leading from the subwoofer to the wall would cover in area, plus the attenuation from the inverse square law due to the distance.
Thoughts?
Suppose, in an open area, you have a ten foot by ten foot wall of infinite density.
If a subwoofer is directly against this wall, how isolated from the sound of the subwoofer will you be, if standing on the other side of the wall?
Thoughts?
