Soundmixer
- Joined
- Mar 8, 2021
- Messages
- 433
- Likes
- 296
I think 9.1.6 is overkill in the OP's size room. My small HT is 10x13x8', and 7.1.2 is all I needed to fill that room with immersive sound. I would ditch the wides, Atmos nor X supports it on disc. Also, you don't need 6 ceiling-mounted speakers in this size room, there isn't enough separation between the speakers to make a difference.
In this size room, you don't need more than two subs since you only have one row of seats. In my room, I used just one big sub placed midwall front on a 17" stand. I would also recommend using mini-monitors like the SVS prime satellites.
I really do think 9.1.6 is just too much for this size room.
