Yes, I know them, I life in the Stuttgart area and would need ~10 Minutes with the car to reach them.
The acoustic concept they use makes sense to me, only thing I dont like much is their Speakers. They use B&W, Swans and Monitor Audio Speakers, for their “highend” stuff they build the speakers by themselves. Even if they get the frequency response flat on axis, these are some basic speaker cabinets, no comparison to the pro stuff in my opinion.
Need to say, I really like the look of your front wall, the wood panels make a huge difference compared to the “classic” black cinema walls. Aren't optical reflections from the projector an issue? Need to think about it, perhaps I should really go this way and use a bigger cinema screen. It should easily be possible to place the projector in another room to avoid hearing it, there is just a drywall in the back of the room. (to make it symmetrical)
I really think of combining the Genelec main monitors (Like 1238DF or A) and the Ones (8341A) + flush mount kit to get the benefits from in wall mounting like “test1223” mentioned. This would also be the recommendation from Genelec, I've already read their informations about this topic.
I (kind of) know Neumann speakers. My first real loudspeaker was the predecessor of the KH310, the Klein + Hummel O300. Room was unsymmetrical and had a terrible resonance in the deep bass area, despite it this speaker gave me goosebumps.
It will be my nearfiled desktop setup soon. For my project the only reason I wasn't thinking of using Neumann speakers is that I can integrate Genelecs easier because they offer much more different speakers. On the other side, 7 KH420 (which can be flush mounted at the front wall and back wall) and 4 KH120 + Trinnov Altitude 16 or Storm ISP Elite + 4 KH750 Subwoofers would cost little bit less than the Genelec setup. Listening distances are minimum ~1,5m wich is OK for the KH420. Not so easy
There will be no cinema seats since I want to play video games in this room with keyboard and mouse, the best solution in my opinion is a couch for two persons.
Sure I will let you know which solution I have chosen, project will start in the summer next year.
Best regards,
Jan
