411: Yamaha TSR 7810 speaker levels after YPAO
dmoss74
hi,
I finally got around to doing the YPAO calibration with my Yamaha TSR 7810, but I'd like to do some manual adjustments to individual speakers.
I have a Radio Shack analog sound level meter and know how to use it. What I need to do is have each speaker (3.1 setup for now) generate a continuous tone, so I can manually adjust them. I've gone through the audio menu and can't find it.
Is that even available on these units?
Thanks for any help.
GD Fan
NY, NY USA
You'd probably need a separate source for sound - a pink noise CD or something similar. But REW will be much more revealing than a simple SPL meter. If you have a laptop you can plug in and a mic.
My experience using Yamaha, Onkyo, and now Denon AVRs is that Yamaha's YPAO does benefit from a lot of manual tweaking.
Best of luck. Let us know how it goes.
D
dmoss74
thanks. i'll look into the rew.
