Hi, how would you recommend connecting a PC with a DAC which is 20 meters away?
AFAIK, I have two options:
- active USB 2.0 cables
- Toslink cables
With both solutions I'm worried about if there is degradation in jitter and also bit-loss.
Also, for the Toslink cable, I'd need to basically buy a USB-DAC or a DAC like device which is converting from USB to Toslink. Do you have any recommendations for such devices? From what I found they are almost as expensive as "real" DACs, so it's a bit pointless at that point.
- Toslink cables
