My Triangle and Yamaha network amp is not the most bright sounding combination (despite what you might think) so i tried what i have of speaker cable.
Then i tried my M-Audio M-Track Solo and it dit sound a little brighter then using my cheap asus pci soundcard (to get optical,toslink out from my pc) with a dh labs toslink cable of good quality, general no bad
Only problem is gain, i have volume trim at + 8db on the amp (that is what it had when i used that input for my turntable, built in phonostage in my tt) and 8 on the soundcard but still a little low (same goes for a mackie onyx artist 1.2 usb soundcard,interface when i had one)
If i want something with gain control instead of a pci soundcard at 100%, it could be a usb studio soundcard (or dac), the one i have from M-Audio sounds fine but it needs to have higher gain
Just a little more expensive than my M-Audio M track solo, 60-70 euros, nothing crazy
What would you recommend ?
