SuicideSquid
- Joined
- Jan 20, 2022
- Messages
- 702
- Likes
- 1,658
Hi guys,
I'm pulling my hair out at a problem and hoping someone here can give me a suggestion. Here's the background:
We've been renovating our family home for the past two years and haven't been living there - we've been in two apartments over that time, but last week we finally got to move in. I wired the living room for surround sound and atmos, with four overhead speakers and outlets for three surround speakers. I'm currently running a 5.1.4 setup. All of the wiring in the house is new - all the in-wall speaker wire is 14-gauge, all the electrical wiring is brand new and up to modern code.
The setup:
Receiver: Denon AVRX4700H (preamp for front channels, power amp for overhead/surround channels)
Amplifier: Buckeye 6-channel Hypex NC252 (for front 3 channels)
Active Crossover: Dayton Audio DSP-408
Speakers: Totem Forest mains, custom centre and surrounds based on Totem Model 1 and Signature 1 for centre and surrounds, generic 6.5" ceiling speakers.
PC: AMD 3600 CPU, nVidia GeForce 4070 GPU, Asrock motherboard, 32GB RAM, 700 watt power supply.
TV: Vizio M65 2019 model
The problem:
Everything works and sounds great from any source but my PC. When I'm using my PC as the source, any time there's load on the GPU, even as simple as redrawing the mouse cursor, it creates a buzz. If I move the mouse around the screen it's like there's a mosquito coming out of my speakers. In games it can switch between no noise at all to all kinds of obnoxious noise depending on what's being drawn on the screen.
This was not an issue until we moved, that I'm aware of. But here's where it gets a bit weird - the noise is only in the rear and overhead channels. There's no noise in the front channels. If I switch from surround to stereo mode, there's no noise at all. I'm uncertain if this is because the front channels are being powered by the Buckeye amp, or if it's something to do with where the noise is coming from - prior to moving I was not using the Buckeye, I was using the internal Denon amplifier, and I was only running in stereo mode.
Here's what I've done to troubleshoot the issue so far:
1. Disassembled and cleaned the PC and ensured everything is properly seated;
2. Swapped HDMI cables from the PC to the receiver, and from the receiver to the TV;
3. Tried routing the HDMI signal from the PC directly to the TV with audio returning to the receiver via eARC - this got rid of the noise, but I think because it would only output a stereo signal when routed this way;
4. Tried swapping out power cables, as well as changing the outlets the PC and receiver are plugged into;
5. Completely disconnected and re-connected everything in my system, all speaker cables, RCA cables, power cables, HDMI, etc - and re-connected everything carefully to be as neat and tidy and avoid cables laying across each other as much as possible;
5. Moved the physical location of the PC relative to the receiver; and
6. Checked the outlets and power bar to confirm that everything's grounded properly.
I haven't yet had a chance to update my video drivers or mess with sample rate but that's the only thing left I can think of that might make a difference. If anyone has any other suggestions they would be VERY much appreciated because this is driving me crazy.
The setup:
The problem:
