Hello,
I've read this site for years now and would like to start my first speaker project!
After quite a bit of research on my own, I could really use a hand. My goal is:
To inexpensively replicate/exceed the sound quality of my old Altec Santana 879A speakers.
[NOTE: The cabinets and rubber were untouched from 1970 and the amplifier in question is a Bryston B-60]
I'm certainly no sound expert but I loved the full tone of the 15" bi-flex woofer.
Tweeter left a bit to be desired, but given the age I expected as much.
While this is indeed my first DIY speaker, my uncle is a master carpenter & cabinet maker.
He's never done this before but his knowledge of woodworking is exceptional.
With the ability to customize a cabinet to any configuration of components,
can I affordably construct a better speaker than I was used to?
As far as budget goes, I'd rather not go above $1,000 CAD for the woofer/tweeter/crossover parts.
However, I know there can be serious diminishing returns after you pass a sweet spot.
Can someone also educate me on what general level of sound quality I can expect for a rough $ range?
Thanks in advance to anyone kind enough to lend their expertise!
- Henry
PS... More information if you need it:
- This is for a 400 sq/ft apartment room enjoyed at low/moderate volume
- There's no genre of music I play more than any other
- The Bryston B-60 amplifier outputs 60W/channel @ 8ohm, 100W/channel @ 4ohm
- My old Altec 879A's were 8ohm impedance with 95-100db efficiency (I believe)
- If pre-made cabinets would perform just like a custom job, that's okay too
- I'd also be happy using a well proven parts list & schematic
- As for max. cabinet size, can we keep it close to my old 879A's?
- Would prefer a min. 12"woofer size - unless you advise otherwise
- Coaxial or separate tweeter, active or passive; whatever produces the best sound quality
- I'm located in Canada but don't mind buying from USA/international if they'll ship to me
- Henry
