The tweeter has a 1st-order high pass, consisting of the 3.3uF capacitor which blocks low frequencies from the tweeter, followed by an attenuator comprised of the 4.7 ohm and 15 ohm resistors.The schematic:
Does this make any sense?
Can somebody point out in the schematic which components, or group of components are responsible for the actual High-pass and low-pass filtering? I assume that there is also an attenuator (or 2) in the schematic. If so, where is it?
You're right... See below for v2.It seems to me that something is not right here.
The tweeter is 5.3 Ohms according to the datasheet I posted above:
You moved some parts around, but it looks to me that all the connections are the same. Am I missing something?
You need to calculate the resistance in series with the capacitor to find the crossover. The 4.7 is in series with the 15 ohm when looking from the capacitor. And the tweeter impedance is in parallel with the 15 ohm resistor. If the tweeter is 5.3 ohm that gives 3.9 ohm. Then add the 4.7 ohm series resistor gives you the effective resistance in series with the cap. 4.7+(15||Rs) = 8.6 ohm if Rs=5.3 ohm.The tweeter is 5.3 Ohms according to the datasheet I posted above:
Combine with the 4.7 Ohm a nd 15 Ohm resistors to make 7.9 Ohm.
With the 3.3uF cap and 7.9 Ohm effective resistance, 6.1kHz crossover.
Your measurements with the driver seem to agree!
Since this is well away from the tweeter's natural rolloff, you should see about 6dB/octave in the crossover region, steeper below about 2.6kHz.
This fits Dynaudio's 6dB/octave ethos. You can do better for sure by actually taking the driver's response into account!
Do you have an LCR meter or DATS or other way of measuring inductance? You can measure the woofer inductance directly on the crossover board. You could also do a near-field measurement of the woofer's response with UMIK and REW.
I was speaking about the individual components.That's in series.
In parallel, it's the opposite with a parallel coil blocking/reducing low frequencies and a parallel capacitor blocking/reducing high frequencies. Usually you'll see both series & parallel components. (You can't use them in-parallel alone in this application because low inductive reactance (Ohms) or low capacitive reactance can "short out" the signal from the amplifier. You also need something in series.)
You research "LC" filter to see how high-pass and low-pass filters are made.
Thanks, you are absolutely correct.You need to calculate the resistance in series with the capacitor to find the crossover. The 4.7 is in series with the 15 ohm when looking from the capacitor. And the tweeter impedance is in parallel with the 15 ohm resistor. If the tweeter is 5.3 ohm that gives 3.9 ohm. Then add the 4.7 ohm series resistor gives you the effective resistance in series with the cap. 4.7+(15||Rs) = 8.6 ohm if Rs=5.3 ohm.
Yes, the impedance of the drivers makes a big difference in interacting with the crossover components. For example see MAB's note above and my response.Stupid question here (I know nothing about circuit design) ... does the impedance of the speaker driver need to be taken into account when calculating the effect of the filter? What about the changing impedance when the voice coil heats up? Also, does "back EMF" affect the performance of the XO?
The self heating of the voicecoil will have some effect, but I think it's relatively minor. However the temperature of the speaker surround can make a significant difference, as the cone suspension gets stiff at cold temps which can change the frequency response a noticable amount.
Back-EMF is a component of the speaker's (complex) impedance - "complex" signifying that it's phase is important. In other words it has inductive or capacitive components. Back-EMF raises the impedance.
There is actually a Wikipedia page on this subject.Follow up question: how many % variation from design parameters on the electronic crossover network would you expect from the voice coil heating up from ambient to (say) 60C? Actually, how much does driver impedance rise when it heats up to operational temperature?
I don't want to overstate the case, or my knowledge of it. Amir has posted some speaker measurements he made at cold temps, where the frequency response was significantly different than when measured at normal room temps. He measures the speakers in his garage, and some tests were done when it was cold. Some other data was presented showing that the low frequency speaker resonance changed significantly with temperature.If I am interpreting you correctly, you are saying that the mechanical effects of ambient temperature on speaker drivers is more significant than the relatively minor changes that take place with crossovers?
I would estimate the effect by Googling the temperature coefficient of resistance of copper, such as here: https://www.allaboutcircuits.com/textbook/direct-current/chpt-12/temperature-coefficient-resistance/ . It says the coefficient is 0.004041. So an increase from 20C to 60C increases the resistance by 1.16. That could produce a change of amplitude of 1.3dB, or less, depending on the circuit.Follow up question: how many % variation from design parameters on the electronic crossover network would you expect from the voice coil heating up from ambient to (say) 60C? Actually, how much does driver impedance rise when it heats up to operational temperature?
One of the reasons for concern about fire is that several amplifiers on the market can supply 30 or 40 volts of direct current to a speaker system if the output transistors fail. This high current can heat the voice coil sufficiently to ignite, particularly if the voice coil form is made of paper or other combustible materials. The main concern is for woofers as there is normally no series crossover capacitor to block the flow of DC. The resistance of the series crossover coil is typically less than one ohm and most of the heating occurs at the woofer voice coil. Gordon Gow learned that a few dealers had an actual fire in their showroom from this cause. One salesman had thrown his cup of coffee on the speaker to put it out. Fortunately it is not due to McIntosh amplifiers or speakers. Underwriters Laboratory approval is not required for speakers.
I think it best to show what can happen if a combustible acoustic material is used in a speaker system. Did you ever wonder how this would burn? In this test Doron is used to fill an XR-5 system and it is placed in a dirt area outside of our building in Hillcrest. A match is attached near the center of the woofer cone and ignited, much like what happens if the voice coil form and spider are to ignite. As a result, the fire from the cone ignites the Doron and gradually spreads. The entire system eventually catches fire and is completely destroyed. Impressive! The acoustic material burns with a vengeance. The 8" speaker in the lower left corner had just fallen on the ground. You can see the 12" woofer basket outline at the bottom of the enclosure. The basket and magnet assembly later fall back into the cabinet. The fire ias so hot it melts the thick aluminum extrusion covering the crossover.
There are many effects.I don't want to overstate the case, or my knowledge of it. Amir has posted some speaker measurements he made at cold temps, where the frequency response was significantly different than when measured at normal room temps. He measures the speakers in his garage, and some tests were done when it was cold. Some other data was presented showing that the low frequency speaker resonance changed significantly with temperature.
As for voice coil heating, I don't really know how hot they can get when driven hard. Erin at https://www.erinsaudiocorner.com/ measures Dynamic Range (Instantaneous Compression Test) for the speakers he tests. He describes the test as follows: "The purpose of this test is to illustrate how much (if at all) the output changes as a speaker’s components temperature increases (i.e., voice coils, crossover components) instantaneously". But heating is not the only source of compression - mechanical nonlinearities also can cause reductions in output (suspension gets stiffer as displacement increases), as can the electromagnetic nonlinearity of the coil in the magnetic gap (the force produced decreases as the coil is displaced). So I don't know how to separate the contribution of those various effects (thermal, mechanical, electromagnetic) in Erin's compression data.
Fascinating, thanks for doing the experiment!There are many effects.
I wonder about the audible impact.
Klippel for example has lots of literature on it.
The implication is that these things get really hot:
I'm a bit unclear on how often I operate my speakers in this regime. Given recent discussions about drivers, break-in, and temperature, I thought I would try to see how much a reasonable application of heat affects a driver.
I got some Audax HP210GO woofers in storage for some time. After confirming it operates correctly, and breaking it in (another thread) I measured the parameters at ambient room conditions. I then dangled it in front of a space heater, careful to make sure it was on a gentle setting that didn't create hot spots or overly heat the driver:
I heated the driver for 10 minutes, turned off the heater and measured. I repeated the 10 minute heating and measurement cycle 8 times. After the 5th cycle I moved the heater a bit closer, then after the 7th cycle I moved it really close. I then let the speaker rest unheated at ambient room Temperature for 1.5 hours, then made a 9th and final measurement. Here are the f(s) and Q(ms) trends:
The result is f(s) drops 2.8% in the first ten minutes. Note this is twice the change I observed on this same driver under break-in! After the first ten minutes, further cycles with the heater have little impact to f(s) even as Q(ms) is changing. Even moving the heater slightly closer after run-5 has little additional effect. Moving it really close after run-7 does drop f(s) a bit more to 3.6% lower than initial. I can change f(s) and Q(ms) by over 3% with a space heater.
This rough heater experiment is likely much different than heating with amplifier power to a voice coil. It's more like being exposed a hot environment, I'm pretty sure direct sunlight is more aggressive than what I did. It's likely I never got the woofer to a steady state in any of these measurements, need an oven to do that properly. But I think we can at least see that moderate changes in temperature like what might be experienced in a room will have a few percent impact on the driver's parameters.
Here are R(e) and L(e) trends for this experiment. It does look like the voice-coil was steadily increasing in Temperature, reinforcing that the driver was never in a steady state and different parts were likely warming at different rates. I was directing the hot air at the woofer-cone, so no surprise if the VC is going to respond over a longer period. I am not surprised by this, most divers have dramatically different thermals across different components. I was actually surprised to see these drivers return to baseline after only 1.5 hours after all of this heating. These drivers have small motors, more robust gear like the Dynaudio will heat up and cool down much more slowly. And take lots more heat than a small motor like in these modest Audax units.
Is all of this audible? I have long claimed break-in is real but tiny, and for all practical purposes inaudible. In this case break-in is maybe half the effect of the modest heating I applied here.
Thanks for your input! Its like a sea of information that is starting to make sense. Very exciting! The DATS V3 is on its wayDo you have an LCR meter or DATS or other way of measuring inductance
There was a mistake in the midrange path. I triple checked the schematic, Im pretty sure that its right now. Is there anything out of the ordinary?You moved some parts around, but it looks to me that all the connections are the same
What was the mistake? I've compared the two versions of the schematic several times and haven't found an electrical difference. The components are drawn differently but the network is the same.There was a mistake in the midrange path. I triple checked the schematic, Im pretty sure that its right now. Is there anything out of the ordinary?
