Your Guiding Audio Principles
Sal1950
The Chicago Crusher
Central Fl
I don't believe multichannel audio is the future.. No one wants all those speakers in their lounge. It will remain neich though.
I don't disagree but outside of the lunatic fringe world we live in, how many folks you know have a stereo set of speakers set up correctly in their room? The don't know "imaging" from a hole in the ground, and don't care either. Good stereo is a Bose Wave Radio/CD player.
We're all neichs living inside of neichs. LOL
Sal1950
The Chicago Crusher
Central Fl
watchnerd
watchnerd
Seattle Area, USA
"Good stereo is a Sonos"
Your friends have more $ than mine. :)
We have one on each floor of our office and the millenials rave about how awesome it sounds.
I kept threatening to bring in my little JBL LSR305s to let them know what they could have for half the cost.
Frank Dernie
Oxfordshire
I agree with your points but don't use streaming for classical music, which is about 80% of my listening, because the standard tagging makes everything too difficult to find and I am too lazy to re-tag all my rips now that I am retired and don't need my music on a portable for weekly flights.
watchnerd
watchnerd
Seattle Area, USA
Classical tagging is a complete bitch, 100% agree.
But, for me:
a) I no longer have the 1000+ classical CDs I ripped, so no other option
b) I haven't bought CDs in years, so all the recent stuff only exist as files, using whatever effed up tagging the vendor used, also no other option
c) As big as my classical selection is, Tidal has more, and sometimes I go on weird binges ('Hey, let's listen to everything Karajan ever recorded' or 'Hey, let's listen to every recording of Tosca ever made")
Fitzcaraldo215
But, for me:
Agreed, classical tagging is a big problem. Tidal has not solved it satisfactorally, nor has Roon, etc. Ironically, it takes only a few specific additional tag fields (composer, composition, etc.) beyond the standard artist-album-song tagging model used for pop/rock/jazz, etc. And, yes, the metadata supplied with the disc/download varies from only fair to non-existent. Quality classical tagging just seems to require manual input and editing, much more so than other genres.
With help from a good and knowledgeable friend, we have pretty much solved it using JRiver and its custom tag field capability with the addition of only one essential custom field to their standard scheme. My library is well over 3,000 discs = many tens of thousands of tracks, mostly Mch, which JRiver handles nicely. I do not do CDs, but his library also includes well over 5,000 CDs tagged using MusiChi, which is very classically-oriented, although limited to stereo and PCM material. He has converted that easily to JRiver, which he prefers for playback and consistency with his SACD and BD audio and video libraries. We each have 52TB NAS's dedicated to music, each now approaching the need for an additional 20TB expansion.
But, my pleasure is browsing my library on an iPad using the excellent JRemote app from the comfort of my easy chair and playing exactly what I want without getting up, lazy ass that I am.
watchnerd
watchnerd
Seattle Area, USA
Another one, this one is for @Thomas savage:
Spending time and money on audiophile fuses is a sure sign that you need to reexamine your priorities.
Or you're as rich as Croesus and have run out of audio things to buy, in which case it's still dumb and you should go buy another supercar, instead.
Frank Dernie
Oxfordshire
But, for me:
I joined qobuz which has a big classical collection but almost useless tagging of tracks. I may not continue with my subscription into a 3rd year since I don't enjoy trying to find exactly what I want.
I could take time to rip then re-tag but a quick check showed that it usually took me about 30 minutes of irritation and boredom to tag a CD I have just ripped. Since I can find a CD and put it on my CD player in about 20 secs that meant for most of my CDs I will waste less time during the rest of my life by not re-tagging, so I only rip pop music.
I gave away my PC when I retired and no longer needed it so the 2 recommended bits of classical tagging software are not available to me.
RogerD
1. Buy the most transparent,high resolution and coherent equipment you can,not dependent on price
2. Anything that expands the sound stage and increases clarity is good.
3. Grounding,grounding,grounding: Signal and Chassis
4.Focus on bass reproduction articulation as that effects the mid range,high frequencies
5 Dedicated 20 amp circuit 10 awg is a good foundation.
D
Deleted member 65
Guest
Agree with watchnerd's list with the following addition:
2. The transducers, speakers, headphones, & cartridges, are next most important.
2.a: Never again invest in a speaker with metal drivers.
2.b: Never invest in a box speaker lacking an AMT driver.
watchnerd
watchnerd
Seattle Area, USA
Wow...that's highly specific!
So soft dome tweeters are out?
D
Deleted member 65
Guest
Yes, having had Elac's, Evolution Acoustics MMMicroOnes (still have in storage) and currently Gauder Akustik's Arcona 100 all equipped with AMT's I love them. Resemble Martin Logan's I guess in the treble. However ML's are out since we have two cats and spouse and I usually listen to music together. ML's panels sweet spot is too narrow, can't afford two pairs.
Wont tire you with my long history with dome tweeters.
Sal1950
The Chicago Crusher
Central Fl
There's some horn lovers here that would disagree with that.
watchnerd
watchnerd
Seattle Area, USA
What do you think of Adam or Eve monitors?
