Did you find it? It’s on Crutchfieds site…RB-1552MKII.
The output from the RCA output of a preamplifier is usually 6 dB lower than the XLR's output of the same amplifier, that's probably almost always the case. That has nothing to do with "Gain". When you refer to gain, you will likely be referring the to the gain of the power amplifiers that have both XLR and RCA inputs. In that case, depending on the specific design of the power amplifier, you could have the following possibilities:
1) The gain will be the same whether you use the XLR or RCA inputs. Examples: many Hypex module based amps, the newer ATI amps, some Parasound amps.
2) The gain will be 6 dB lower if the XLR inputs are used. Examples: Bryston, Marantz, and many more..
3) The gain will be lower but not necessarily 6 dB lower if the XLR inputs are used. Examples: the Rotel amp you cited, some Outlaw amps.
If that spec is important to you, then all you have to do is to read the specifications and if it is not included in their documentation, contact the manufacturer.
