I think you guys in the US are getting a taste of the type of weather we get every summer here in Australia at the moment. You need decent heatsinks here. And several airconditioners.
True. Increasingly, engineers making devices in consumer electronics sector will need to take into account climate change and gradually raising temperatures when designing heat solutions. Apart from real life drama that is going to unfold in next 10-15 years in different places on the planet..., devices will also need to operate in higher average temperatures, so more robust heat solutions will be needed anyway across the board.
As with anything, a device itself could have effective heat solution, but if placed in wrong space, such as confined surroundings or closed cabinet without any airflow, it's going to suffer no matter how good heat solution is.
By the way, heatsink systems on A6A and A8A do look more robust and thought through than in previous generations. New receivers are 1 and 2 kg havier, have thicker and wider H-cross rail, cases have more metal surface touching other metal parts, there is additional fan on A6A for HDMI board chip, heat spreaders on the three HDMI 2.1 chips are bigger, etc. All in all, entire case seems better equipped to play the role of passive heat solution. Once reviewers publish their measurements, we will know more.
