It may not be fair, but if you read the comments and threads on this forum either praising or complaining about SINAD scores and other measurements and their influence on whether somebody is considering a product for purchase - they now won't even give it an audition because it is not in the blue or green area. So on the one hand, we as consumers should absolutely buy what we find pleasant, but how do we know if we're missing out on something pleasant if we've already discounted it without a listen due to objective scores?
Again, this is not fair.
A properly designed solid state class AB or class D amp will sound exactly the same as any other. This has been established so many times that it's simply not worth doing auditions anymore. Buy the one with the features and measurements to suit your needs and don't allow yourself to be fooled by psychoacoustics. Most of the people you're referring to acknowledge they probably can't hear a difference between these devices and are simply chasing engineering excellence for the sake of it, which is fine, and honest.
Tube amps and solid state amps measure differently in ways that are clearly audible, and listeners can tell them apart in blind ABX listening tests, so there's a purpose to comparing them with a listening test, if you're interested in a tube system.
There are three scenarios in the audio world where measurements and listening tests may come into play:
1. There is no measurable difference, audiophiles claim to hear a difference, and these claims disappear in blind ABX testing (best example: Cables). In this case, buy whatever, it doesn't matter.
2. There is a measureable difference, audiophiles claim to hear a difference, but it fall below the threshold of audibility and the claim to be able to hear a difference disappears in blind ABX testing (best example: solid state amplifiers). In this case, buy whatever meets your feature and performance targets, listening tests don't matter.
3. There is a measurable difference that is audible in blind ABX tests. In this case, buy whatever sounds best to you, regardless of whether it measures "better" or not, but acknowledge if you prefer the "objectively inferior" product, your preference doesn't reflect some magical unmeasurable property in the thing you like, but is merely an expression of your personal preferences. (Examples: Tube vs. solid state, vinyl vs. digital, 'flat' speakers vs. speakers with a 'house sound')
