The
Both comes from same old master mix and have very similar loudness and RMS statistics. But there's an MM capsule that add a non linear response. So I take another good album from Tracy Chapman (1988) to make same comparison between CD and Vinyl (clean, no clicks) and curiously all loudness (BS1770) statistics are equal (-1 dB track normalized), so we can better compare frequency response
Upper picture is CD and almost identical to vinyl FR so it seems same master to me.
Now it's clear that HR digital track from America is completely wrong in high frequency, probably old backed tape or tape recorder with issues on read head.
I have repeated this experiment with many old records and always the digital version is seriously compromised if not completely mutilated by digital processing, only exception is a hi res Grand Funk recording that fortunately was transferred with a good tape machine and without any DSP, it's possible to see on FFT real tape capabilities without Dolby or brutal compression with bass information that don't fit on the restricted groove modulation of vinyl.
The FR of any cartridge is driven first by the effective tip mass of the stylus - which is mostly driven by the cantilever mass - this will in turn generate a resonance - with this type of stylus, most likely around 12 to 14kHz - so the bare bones response before any processing, coming from the cartridge will have a bell shaped resonance curve around 13kHz or thereabouts.
Then the circuit formed by Cartridge inductance, and load impedance and capacitance, will adjust this, and provide its own EQ - this is typically used to control the cantilever resonance and achieve a flat F/R in combination with the RIAA EQ.
The problem with all this is - you need to know what the cartridge and stylus are, and then whether the precise parameters required for a flat F/R have been met. How many people actually know their effective C load?... it's not just the phono stage, but the cabling in the arm, and the cabling leading to the phono stage + whatever load is applied within the phono stage.
Those running with MC cartridges can pretty much disregard capacitance issues, as due to the tiny inductance of the coils on MC's capacitance has completely negligible impact (yeah you can run 1000pf and it doesn't care). - The downside being, that the raw cantilever resonance cannot be "cancelled out" - and tends to get exposed.... (why do so many MC's have a "bright", Rising, high end... making them sound more "detailed"...)
But lots of excellent turntables are then ruined by people putting heavy, audiophile looking interconnects on them... unfortunately most of the heavy audiophile interconnects have high to very high capacitance - not unusual to see 450pf.... whereas the thin and ordinary looking cables connected to many 1980's turntables, have a total capacitance of under 100pf.
Specifications for the AT VM540L are that it should be loaded with between 100-200pf (and by the way that range would imply 2 to 3db of potential difference in high frequency response at least... ie: between 100pf and 200pf there can be quite a difference).
If you have proper low C cabling - the cabling alone will take you to 100pf - lots of phono pre's default to around 200pf internal C load.... which puts the poor cartridge at 300pf and well outside of its specified loading.
What I am trying to say - if you want to make this sort of comparison, you need to know in detail the setup that was used for the Vinyl replay, and it needs to have been measured and confirmed for a flat Frequency Response - otherwise it is not meaningful.
With a properly measured setup, digital EQ can potentially also be applied to adjust as needed to achieve the optimal flat F/R... (Technics new TOTL integrated, provides exactly that function, with a test record provided with the integrated for testing and automated EQ... - but for the rest of us, this is a very manual process)
