mdsimon2
I do think it is worth discussing how folks do volume control when using a pro audio interface that does not have a IR receiver. So far I have come up with a few solutions but am very interested in other ones.
1) Volume control in CamillaDSP
I mentioned this previously but if you set up the CamillaDSP web interface you can use you this as a volume control from a phone / remote / computer. When you pull it up on a phone you can adjust the volume without any scrolling, see below for a screenshot. The slider between In and Out is the volume slider.
2) miniDSP 2X4HD or SHD Studio as volume control
If you are using external sources (TOSLINK, analog, etc) these work really well as they have bi-directional USB audio, IR receivers and digital volume control implement in their SHARC DSPs. This means that if you use them as a capture device in CamillaDSP they can provide volume control without any DA conversion. SHD Studio obviously has much more input flexibility (and Dirac) but is rather expensive. 2X4HD has much less input functionality but is cheaper and can be upgraded to a DDRC-24 for $200.
3) As a variation to option 1 you can also add a FLIRC IR receiver and use a remote to control CamillaDPS volume. This definitely requires some tinkering and is less plug and play than the other options.
4) You can also add displays to either option but that is not exactly plug and play. I show some examples in this post (and in posts linked in that post).
What I am most curious about is if anyone knows of a product in the 2X4HD price range that has bi-directional USB, DSP based digital volume control (i.e. NOT using DAC volume control), an IR receiver and most importantly a display?
Michael
Michael
