VientoB
Why is there this difference and doesnt it mean that you have to turn your volume knob down when using XLR and isnt that not so good as the pot is attenuating the signal more?
Not if the amplifier with the XLR input is designed to recognise that the likely incoming signal with be twice the voltage. It should be half the sensitivity of the Unbalanced inputs.… it mean that you have to turn your volume knob down when using XLR and isnt that not so good as the pot is attenuating the signal more?
I'm not sure if you quite meant what I understood you to write:-Balanced outputs in recording studios often went to low impedance transformer inputs, 150, 200, or 600 Ohms, capable of running hundreds of feet. Single-ended inputs went to bridging inputs 10 Kilohms on up and most people would keep them short, under 10 feet.
Well, no. Nominal (average) unbalanced line level in the olden days was 300 mV (-10 dBV). 2 Vrms then provided a rather sensible 16.4 dB of headroom (for pop music, anyway). Amplifiers were typically designed to provide up to 6 dB gain to spare for quieter cartridges or whatnot, so they would have a 150-200 mV input sensitivity.'Red Book' CD players decided to standardise on 2V being the output and the volume controls of these amps were then cramped down to just off minimum and usually never more than 25% up before the amp began to clip
And indeed, playing some of my CDs from the early 1980s, there was typically something like 10dB of headroom left. None of this slamming the audio to 0dBFS and keeping it there for a long time with compression and limiting.Well, no. Nominal (average) unbalanced line level in the olden days was 300 mV (-10 dBV). 2 Vrms then provided a rather sensible 16.4 dB of headroom (for pop music, anyway). Amplifiers were typically designed to provide up to 6 dB gain to spare for quieter cartridges or whatnot, so they would have a 150-200 mV input sensitivity.
It was the CDs that got louder and ruined the whole deal. 10 dB often is enough to get amplifier volume pots into "touchy with declining channel balance" territory.
