Newbie question: would it be reasonable to power two Aiyima A07 units from a single Mean Well LRS-350-48? It appears there are multiple DC outputs and adequate power available, but I don't know whether that's how they're designed to be used.
no data - i'm not have this device. in the description saw a mention pcm5242, but I can't guarantee thats it's true, sorryI would be curious what DAC does it have? in the characteristics it does not specify it.
Their product info says:Before I pull the trigger on purchasing Aiyima 07 from Aliexpress, I need to know which power supply to get?
DC48V 7.5a switching POWER ADAPTER, 110v or 220v which volt? I live in Texas (USA) btw
I appreciate your help
i wouldnt recommend it unless you were keeping the power consumption low on each of the units. at full bore each of these units should be able to pull around 6-6.5A
Thanks - I don't think I'm gonna be anywhere near full bore. I'm more wondering whether it's "correct" to use a single power supply for two different units than about the power consumption. The use case is for two sets of bookshelf speakers - small (Elac Debut 6.2) in the living room, and smaller (Denon SC-M41) in the kitchen for mostly low volume listening. I'm imagining that I'll be using a max of about 10% of the available power on the Denon's and maybe double that on the Elacs.
I'll check those guesstimates/assumptions with a meter before hooking up a second unit to the power supply, but as long as I'm not approaching the 7.3A the PSU is rated for, would it be reasonable to have them share a power supply? A big part of what's appealing to me about these amps in this context is the small footprint, so it would be ideal to be able to avoid using two.
Anyone tried using the Aiyima A04 with a Denon AVR?
I ask everyone but especially aiyima if you are reading: with aiyima A07 I would like to drive 2 kef q350, which class D amplifier to connect to a subwoofer do you recommend, to cut the frequencies from 80hz, without spending too much money?
is it 'correct', no, it's not. can you do it despite what we are telling you, sure, sounds like you are going to anyway. not sure the logistics of the layout that lets you share a single unit without massive wire runs, but whatever man, have at it.
Definitely 110v
Mean Well LRS-350-48 seems to meet the needed specs but is a raw power supply that you'd need to hook up bare terminals to the appropriate cables and potentially cover.
Are you seeing anything that meets Aiyima's specs that is more of a finished product? I'm not seeing much.
Looks good. Similar to the Mean Well but a bit heftier (and pricier). Are you planning to house it in something?I bought this and it's fine
https://www.amazon.it/gp/product/B075ZTWZQJ/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
it's perfect as it is ... I just put a resistor on the fan cable to make it quieterLooks good. Similar to the Mean Well but a bit heftier (and pricier). Are you planning to house it in something?
Definitely 110v
What cables and what power supply, some pics would helped.Does anyone know how the individual cables should be connected to the power supply?
For all the supplies I've looked at the MeanWell datasheets have included everything you need to know. If you don't understand the datasheet then you should probably find a friend locally who has some experience and can guide you and check that you've done it safely. You're dealing with voltages that can kill and more than enough power to start a fire if you get it wrong.Does anyone know how the individual cables should be connected to the power supply?
